Recommend Best A/V Receiver Around $500? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-13-2014, 08:57 AM - Thread Starter
assassin's Avatar
Quoted: 51 Post(s)
Liked: 241
Need some current recommendations for the best AV receiver under (or around) $500. Would need to be 7.1 and at least 5 HDMI inputs.
Thanks in advance.
assassin is offline
post #2 of 6 Old 01-13-2014, 09:26 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
Can you tell us about your room size, the speakers you are using, your listening preferences and what you will be hooking up as sources?
bladerunner6 is offline
post #3 of 6 Old 01-13-2014, 09:33 AM - Thread Starter
assassin's Avatar
Quoted: 51 Post(s)
Liked: 241
Sure. Obviously those are great questions. I will try my best.
I am actually helping a friend design his theater in his basement. He has a cheap Sony 5.1 HTIB now. I would categorize him as what I call an "Average Joe Best Buy Guy" ---- he is definitely not an audiophile. His main listening will be mainly Dish TV, Xbox, Playstation, Bluray player, a HTPC and probably MP3s.
He has purchased an Epson Pro projector and I have recommended that he mount it and play around with the screen size before he purchases a screen for it.
I will have to ask him about the dimensions of his room. He is also not sure what he is going to do as far as speakers are concerned. He might need to use in-walls for the 4 rears based on how his room is setup (large opening at the back of the room that opens to another room in the basement --- no doors but enough wall on each side for a rear back on each side.)
assassin is offline
post #4 of 6 Old 01-13-2014, 03:25 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 10296 Post(s)
Liked: 4766
Unless he plans on placing the rears on pedestals, he may simply want to consider the "side" in-walls and stop at 5.1 (or consider Front Height speakers for 7.1). Take a look at the Denon E400, X1000 and X2000.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Authorized dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, SVS, Oppo
Ask me how to get a FREE HEOS 1 HS2 wireless/Bluetooth speaker.
jdsmoothie is offline
post #5 of 6 Old 01-13-2014, 03:52 PM
Quoted: 68 Post(s)
Liked: 111
I like the Denons myself, but Yamaha would be my second pick.
rnatalli is offline
post #6 of 6 Old 01-13-2014, 04:15 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
I prefer the Yamaha's over the Denon's. Not that crazy about Audyssey in the forms I've used. Multi-Eq XT is as high I used. Can't comment on XT32. The Yamaha below seems to be a good buy in this price range.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115377&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6146852&SID=1nblsghug0pef
phantom52 is offline
Denon Avr X2000 7 1 Channel Home Theater Receiver , Denon Avr X1000 5 1 Channel Home Theater Receiver , Denon Avr E400
