Should I be worried about receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-14-2014, 08:41 PM - Thread Starter
gotexas872's Avatar
I was playing my new setup the other day and my receiver shut-off after playing music for 15 minutes at -2 dB. I let the receiver cool down for 30 minutes and gave it another run. After five minutes of watching over the air t.v. at a volume of -35 dB I heard a loud popping noise come from the speakers. I immediately turned the receiver off and waited a day to turn on my receiver again. The next day, before playing any audio, I made some changes in the receiver settings and watched t.v. for 2 hours then a movies for 2 hours at -25dB and did not have the popping noise problem again.
My question is if my receiver settings and/or not letting my receiver cool long enough could have been the culprit of either 1) my receiver overheating or 2) the loud popping noise? These are the settings I changed the following day:
Amp Assign - From: Front B To: Normal
Volume Limit - From: -20dB To:-10dB
Floor Left Volume - From: 1dB To: 0dB
I have a pair of Acoustech PL-76 floor-standing speakers connected to a Denon 1611 receiver. Here are the specs for the speakers and receiver:
Acoustech PL-76 Specs
Design: Video-shielded 200-watt (500-watt peak) 2-way horn tower with dual 6 1/2" woofers.
Frequency Response: 30Hz- 23kHz
Sensitivity: 96dB @ 1 watt, 1 meter
Recommended Power: 10-200 watts per channel RMS, 500 watts peak power
Impedance: 8 ohms
Denon 1611/591
Surround System Class 7.1 channel
Amplifier Output Details 75.0 Watt - 8.0 Ohm - 20 - 20000 Hz - THD 0.7 % - 5.0 channel(s) ( Surround ),
120.0 Watt - 6.0 Ohm - THD 0.08 % - 5.0 channel(s) ( Surround )
Thanks for any feedback.
gotexas872 is offline
post #2 of 6 Old 01-14-2014, 08:48 PM
carminepesce's Avatar
Quoted: 40 Post(s)
Liked: 44
Are you running your receiver within an audio rack or cabinet?
Panasonic 50" ST50 Plasma
Outlaw Model 5000 Amp
Yamaha CX-A 5000 Pre/Pro
Oppo BDP-103D Bluray player
SVS PB-1000 Sub w/DSpeaker Anti-Mode 8033s ii
SVS Prime System
carminepesce is offline
post #3 of 6 Old 01-14-2014, 09:00 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you add a subwoofer it'll take a load off your receiver by not having to produce the low frequencies. And yes if its not ventilated that'll cause problems too.
I have a Denon 591 with an Energy RC-10 pair, RC LCR setup but I also have a powered sub. No problems at all but I doubt I've ever run it at -2db more than a few seconds.
Afro GT
afrogt is offline
post #4 of 6 Old 01-14-2014, 11:50 PM - Thread Starter
gotexas872's Avatar
I have my AVR placed on a night stand with no barriers around it.
Is there a setting on my receiver that I can change so that my front speakers will safely produce the lower frequencies? I do not have a subwoofer yet.
Thanks for the feedback guys!
post #5 of 6 Old 01-15-2014, 12:08 AM
afrogt's Avatar
Liked: 755
you could set subwoofer to YES and then set your speakers to small and change the crossover to 60hz or 80hz.
If your speakers cannot truly go as low as the specs say then setting a higher crossover point might alleviate your problem.
Afro GT
afrogt is offline
post #6 of 6 Old 01-15-2014, 12:19 AM - Thread Starter
gotexas872's Avatar
Okay. Thanks. I will give that a try. And doing this may or may not help with the overheating or loud popping noise I heard?
Bic Acoustech Pl 76 Tower Speaker , Denon Avr 1611 7 1 Channel A V Home Theater Receiver , Denon Avr 591 Receiver
