Looking for the "right" sized receiver for my set up. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-17-2014, 05:56 PM - Thread Starter
Acousticality's Avatar
Hello everyone,
I currently have an Onkyo TX-NR805 7.1 receiver. (135W X 7 channels)
My set up is as follows:
Center: Polk Audio CSi5
Front R/L: RTiA5
Surround R/L: Monitor 30iB
Surround back R/L: FXAi6
Subwoofer: Polk PSW505 Powered
I am looking to upgrade to a new receiver since I got a new HDTV and would like something with enough power for these speakers. Additionally, I would like 3D and 4K pass-through for if I ever upgrade to 4K in the future.
Any suggestions?
Acousticality is offline
post #2 of 10 Old 01-17-2014, 06:21 PM - Thread Starter
Oh, and I would like to stay below $1000 max.
post #3 of 10 Old 01-17-2014, 06:27 PM
jdsmoothie's Avatar
Quoted: 12094 Post(s)
Liked: 5504
As the 805 uses Audyssey MultEQ XT, you'll likely want to upgrade to the more advanced XT32 which can be found on the Onkyo 929 (if you want to stick with Onkyo) as well as the Denon X4000. The Denon also features Audyssey Sub EQ HT (dual sub calibration) should you ever decide to add a 2nd sub to your setup, a feature not found on the 929.
jdsmoothie is offline
post #4 of 10 Old 01-17-2014, 06:33 PM - Thread Starter
Those are both above my budget.
post #5 of 10 Old 01-17-2014, 07:01 PM - Thread Starter
What about the Marantz 5008?
However, I see on Marantz website that pretty much everything is made in China.
post #6 of 10 Old 01-17-2014, 07:02 PM - Thread Starter
or the Yamaha Aventage A830?
post #7 of 10 Old 01-17-2014, 10:40 PM - Thread Starter
Any recommendations?
post #8 of 10 Old 01-18-2014, 12:16 AM
jdsmoothie's Avatar
Liked: 5504
The 5008 uses the same version of Audyssey MultEQ XT as does the 805 and the A830 would use Yamaha's own brand of EQ (YPAO), although it cannot EQ the subwoofer, rather you would have to upgrade to the A2030 for that feature.
post #9 of 10 Old 01-18-2014, 12:20 AM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3079
All the AVRs are made in China with the exception of the flagship >$1000 models for each of the brands. I wouldn't worry about that. The Marantz 5008 is a fine receiver with Audyssey XT, 7.1 pre-outs, etc. The Yamaha Aventage A830 has a similar complement of features. It also features the more advanced version of YPAO, YPAO R.S.C.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #10 of 10 Old 01-18-2014, 02:36 PM - Thread Starter
Actually most of Onkyo's stuff is made in either Malaysia or their higher end stuff is made in Japan still.
Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Onkyo Tx Nr929 9 2 Channel Network A V Receiver , Yamaha Rx A830 7 2 Channel Network Aventage Home Theater Receiver
