[doubt] Yamaha RX-V475 vs Denon AVR-E300 vs Pioneer Elite VSX-43 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-18-2014, 09:47 AM - Thread Starter
albertoivo's Avatar
Hello,
Which one of these 3 receivers would you recommend to 4 bookshelves Klipsch B-20, Center Channel Klipsch C-20 and a BIC America F12 Subwoofer:
I won't be able to listening to them with any speaker. So I will just trust in your opinions. Considering their prices and features are quite the same. Except for the pioneer that is 7.1. But I don't think I will use 7.1 on my small room.
Thanks in advance!
albertoivo is offline
post #2 of 4 Old 01-18-2014, 09:53 AM
jdsmoothie's Avatar
Quoted: 12093 Post(s)
Liked: 5503
Each uses a different type of auto speaker EQ system, although the E300 is the only one that can EQ the subwoofer in addition to the speakers. Review the feature set of each model from the mfr's website to see which ones offer the features you require and which do not.
jdsmoothie is online now
post #3 of 4 Old 01-18-2014, 09:57 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
My experience has been that Denon has better amplifiers, and I would recommend them.
Marantz would be even better-sounding IMO, but more expensive of course.
commsysman is offline
post #4 of 4 Old 01-18-2014, 10:12 AM - Thread Starter
albertoivo's Avatar
That's a good advantage to Denon.
Which Marantz would you recommend in this range of price: NR1403 ?
My doubt about these Denon and Yamaha is because I read a review at stereo . com this Yamaha (in their opinion) is the best budget receiver.
Pioneer Elite Vsx 43 , Denon Avr E300 , Yamaha Rx V475 5 1 Channel Network Av Receiver
