Yamaha Rx-a730--hooking up an external amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-20-2014, 06:02 AM - Thread Starter
JimmyJam19's Avatar
Quoted: 13 Post(s)
Hi guys,
I have two tower klipsch speakers that I want to run in stereo on my 7.2 configuration. I bought the yamaha rx-a730 because the guy told me I could hook an extternal amplifier to it, but I'm confused as to where I hook this up on the back of the receiver or even what external amplifier to use. I appreciate your help.
Here is my av receiver
http://www.amazon.com/Yamaha-RX-A730-7-2-Channel-AVENTAGE-Receiver/dp/B00BQHCC48
JimmyJam19 is offline
post #2 of 2 Old 01-20-2014, 06:25 AM
smitty8451's Avatar
Quoted: 63 Post(s)
Liked: 86
I hate to tell you this but the saleperson was mistaken. That particular unit does not have pre amp outs built in to it so you cannot connect an external amplifier. I believe that is possible with the Aventage RX-A830 series on up. If you can or need external amplification I would recommend taking it back and getting an RX-A1030 or look and see it there are any RX-A1020 or -2020 units left from last year. As they are last years model they will be heavily discounted. Hope this helps, and the best way to keep a salesperson straight is to do some thorough research before you start looking, with all the newer stuff coming out a lot of sales people just don't keep up with the technology or what each individual unit is capable of doing. You want to look for a unit that has "Pre Amp" outputs. smile.gif
Yamaha CX-A5000, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio Pharaoh Int amp, Sony HAPZ1-ES
smitty8451 is offline
Yamaha Rx A730 7 2 Channel Network Aventage Home Theater Receiver
