Official Pioneer Elite SC-71 Receiver Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #271 of 291 Old 04-04-2015, 06:23 AM
geartech's Avatar
Have a SC72, got it a little over a year ago at Best buy before they had the price drop on them ( Cra*). Anyway the unit appears to be dead now.
Will not power on, Can hold the stby sw for 10sec then release and press again and it will turn on the mains inside and display POWER UP on the unit display.
Won't enter reset mode by holding the enter button and pressing stby switch. Have the unit removed from the stack now with nothing plugged into it to make sure there
isn't an issue with something shorted on an input or speaker. No joy, It's looking like a trip to the repair facility.
At least Pioneer was promt and tried to be as helpful as possible when I called.
geartech is offline
post #272 of 291 Old 04-06-2015, 12:04 PM
zeeoo7's Avatar
Originally Posted by JChin View Post
Hi zeeoo7, utilize HDZone HDMI to TV as the video source and using Main Zone as the music source.
Thanks a lot. I tried this and worked. It just took 10-15 minutes after reading the manual to get more information on the HDZone and set it up.
But, there are two things.
1. It's now not possible to control volume or mute using the other remotes like the TV remote and Cable TV remote. They don't respond. I read somewhere in the manual that the Control with HDMI function won't work when using HDZone.
Am I right? Is there any work around?
2. The response to Cable TV remote functions seems slower after changing the HDZone.
Sony Bravia HX800 55" 240Hz 3D LCD EdgeLit LED
PS4 and PS3 Slim (with 3D Blue Ray player)
Comcast Cable Xfinity X1 DVR (Panasonic HD-DVR)
Bowers & Wilkins 686B Book Shelf Speakers (Front L and R)
BIC America F-12 12" Subwoofer
zeeoo7 is offline
post #273 of 291 Old 04-17-2015, 09:23 PM
dma002's Avatar
Many thanks to all who posted suggestions for tuning the sound of the SC-71! I knee-jerk purchased one this week from Best Buy (NIB, on sale for 549.99, free shipping), and I was afraid I'd made a huge mistake, as the sound seemed very thin compared to the terrific sound of the VSX-1124 I bought from BB a few months ago. After redoing the MCACC setup following the wonderful tips posted here, the sound is much fuller and richer.
I've *always* wanted an Elite, but was never able to afford one. When I saw the SC-71 on sale, all plans of waiting for the VSX-1130 went out the window! I don't recall doing this much tweaking to the MCACC of the 1124, but it's been a while. My plan is for the 1124 to replace the old (but still very functional) VSX-D912 in the bedroom setup, while the SC-71 takes up permanent residence in the living room. I'll keep tweaking, but...so far, so good!
dma002 is offline
post #274 of 291 Old 05-07-2015, 04:06 PM
Indpowr's Avatar
I am at a loss here guys. Please help.
I just got the SC71 and ran mcacc setup and it's registering all speakers and it's setup.
I tris using my PS4 and my BD and neither of the are playing Rear surround and it's not showing on my display.
I have tried every setting Neo etc. I tried 2 dif ferret BD and still nothing. Also voice is not only in center like it should be.
Please help.
Jon
Indpowr is offline
post #275 of 291 Old 05-07-2015, 05:28 PM
goldark's Avatar
Quoted: 209 Post(s)
Liked: 41
To all the owners who were getting weak bass from their mains (without a subwoofer) - how did you get past this? I know I was getting better bass from my old Yamaha, so this shouldn't be the case, right?
goldark is online now
post #276 of 291 Old 05-12-2015, 10:01 PM
dma002's Avatar
There are some really good suggestions a bit further back through this thread; basically, after you run MCACC, you should go into the manual setup and make sure your speakers are set to "Large" (for no subwoofer), then select the "Front Align" profile from the Audio Parameters menu (button).
dma002 is offline
post #277 of 291 Old 05-20-2015, 03:49 PM
Liked: 2
Newbie Questions
Hi all, I'm a home theater novice and just got the SC-71. I am only running back surround speakers. Should those be connected to the Surround outputs on the receiver or the Back Surround outputs? I assume the former as that it what the instructions for my old Sony ES receiver advised.
Bigger question, I have DefTech 8040STs in front and the 8040 surrounds in back, both of which are bipolar. The speaker manual says to NOT use MCACC or similar as those systems are thrown off by bipolar speakers. Any ideas on using MCACC with bipolar speakers.
Last, the fronts have built in subs and I have a separate SuperCube 4000. Can anyone recommend an optimal setting for ensuring that all signals are being passed to the towers? You can connect the towers with LFE and High Level or just High Level. The sub can also be connected either via LFE or High Level.
Thanks for any advice, it's very much appreciated.
aejonesia is offline
post #278 of 291 Old 05-26-2015, 06:21 AM
Gyaf's Avatar
Liked: 0
Purchased a Open Box SC-71 This weekend
Hi everyone
Purchased an open box SC-71 this weekend - Best Buy was selling it for $296; sans remote, av navigator software and manual - and a few surface scratches.
I'm using it to power audio only - 4 outdoor speakers and 2 indoor speakers on Zone 2
Few questions for you geniuses:
1) Is there a way to fully power each of the 4 outdoor speakers and have audio play properly - like using the Front L/R for 2 speakers and the Surround L/R for 2 other speakers?
1a) Does the source matter? I.e. digital sources, such as internet radio or spotify through the unit seem to push power through the amp much differently - prior to getting the internet up and running (I'm using an old linksys router as a client) i had a tablet running spotify hooked up through rca inputs. The internet radio seemed to be pushing a tremendous amount of power to where i was getting feedback, vs, having to turn the volume way up on the tablet feed.
2) Tried using the icontrol app from both an android phone and iphone - my network setup is as follows:
I have a netgear router generating a wireless zone - assume an internal i.p. of 10.0.0.x; in the room with the receiver, i have a linksys router serving as a client, with a internal i.p of 192.168.10.1; the receiver is hardwired into the linksys and is showing an i.p of 192.168.10.135.
When I try to get the icontrol app to find the receiver, it gives me an error code and says it cant find it. Confirmed that my phone is on the same wifi network. Thoughts?
Thanks for any help you can provide!
Gyaf is offline
post #279 of 291 Old 05-27-2015, 08:59 PM
Gyaf's Avatar
Liked: 0
Originally Posted by Gyaf View Post
Hi everyone
Figured it all out - I needed to set up the router as a repeater bridge or client bridge, in order to be on the same network as my wifi, and once i got that running, I was able to use the icontrol app to put the stereo easily into extended stereo mode which seems to fully power the speakers no matter what the source is.
Gyaf is offline
post #280 of 291 Old 06-01-2015, 02:01 PM
Liked: 2
Settings to enable a sub with 2-channel sources?
Hi Everyone,
Does anyone know how to get a sub to run with the front L/R speakers on 2-channel music? I'm unable to run MAACC due to having DefTech biopolars. The only way I've been able to get the sub to run on stereo signals is using surround fields like DPLII Music.
Adam
post #281 of 291 Old 07-10-2015, 10:20 AM
TL24's Avatar
I've read through this thread and there are plenty of suggestions but could you post your suggested setup?
TV: Panasonic Viera VT50 55 | A/V Receiver: Pioneer Elite SC-71 | Speakers: Martin Logan Motion 40's (Bi-Amped) | Cables: AudioQuest Cinnamon HDMI Cables + AudioQuest Rocket 33's (split)
TL24 is offline
post #282 of 291 Old 07-27-2015, 01:56 PM
dma002's Avatar
Well, I'm still tweaking, but...I started by redoing MCACC, then I selected the "Front Align" profile. I also turned off Equalization for this profile - for some reason, it was giving me reduced fullness. After that, I discovered that my levels overall were a bit on the low side; I was turning the receiver up to -12dB for decent sound, and I thought that was too high. I checked my channel levels, and MCACC had set them very conservatively. My fronts were all -5dB or more, with the surrounds set even lower, so I boosted them all to at least 0dB, and I think the sound is much better.
dma002 is offline
post #283 of 291 Old 08-05-2015, 07:13 AM
JJacobs's Avatar
does anyone know where i can buy/borrow a setup mic? i don't know which model i need...got this used so i'm at a loss. thanks for any help provided
JJacobs is offline
post #284 of 291 Old 12-29-2015, 03:34 PM
Liked: 1
Glad i found this thread, as i have the sister of the elite SC-71 on the way.. ( Pioneer SC-1223-K )
my2006 is offline
post #285 of 291 Old 04-27-2016, 08:58 AM
Bocat's Avatar
Need help. I ran my SC-71 with a Sony 40" Bravia for many years. It worked great. The Sony finally died so I purchased a new Samsung 55" UN55JU6500. The cable box works fine but I can't get a picture from either my Sony Bluray or Panasonic Bluray. Everything is set up the same as with the Sony tv. What am I doing wrong?
Bocat is offline
post #286 of 291 Old 04-28-2016, 10:54 AM
Bocat's Avatar
Never mind. Problem solved. It helps if you run the proper HDMI cable into the right input.
Bocat is offline
post #287 of 291 Old 04-28-2016, 06:30 PM
r3v3nant's Avatar
Quoted: 33 Post(s)
Liked: 41
haha ok then. I was going to suggest set video to pass-thru with no signal modification. Glad you figured it out though.
Listening: Outlaw Audio 950 | Pioneer Elite DV-47ai | 2x Marantz MA-700 + 2x MA-6100 | Energy RC-70 bi-amped + Outlaw Ultra-X12
HT: Pioneer Elite SC-71 AVR | LG 60PV450 plasma | all BIC 7 speaker surround + Klipsch sub-12hg | Sony BDP-S350 | WD TV
r3v3nant is offline
post #288 of 291 Old 06-27-2016, 12:56 PM
Erik The Pope's Avatar
Liked: 0
Question about sound...
I inherited a 60" Elite TV which works fine & I was looking for an Elite receiver to go with it. Friday I bought an SC-71 in very nice condition & hooked it up
yesterday. Having lots of trouble with the sound. I've got decent speakers but very weird sound.
Sound with cable TV: left spkr OK, center OK, rt spkr dull sound, no highs.
Bluray, Star Wars, Bonus Disc Ep. IV-VI: L = R very low sound; center = dialog; surround = L only
Bluray, Star Wars, Ep. IV: L = SFX & music; center = dialog; R = weak sound, no highs; surround = L only
DVD, Twin Peaks: L = music, center = dialog, R = weak sound, no highs; surround = L only
Last night the Star Wars disc had no dialog audible at all. The next day the dialog was in the center. I was at Best Buy today & talked to a guy about it & he said
if I reset the unit to factory defaults that might cure it & then I could set it up again.
One thing that's annoying is the instruction manual is on computer disk & it's hard to read & then do whatever. I am going to print out the relevent parts now so
I can tell what's going on.
Also, the Source button on the upper right of the remote doesn't seem to do anything. What's it supposed to do? This receiver is a lot more complicated than the
one I had (Denon) so I am a little confused about it.
Thanks for your responses!
Learn a few songs on the banjo, it's the key to life...
Erik The Pope
Erik The Pope is offline
post #289 of 291 Old 07-09-2016, 11:45 AM
Liked: 0
Apparently there is not much action on this thread. I fixed the problem which was due to bad connections to the speakers. I tried banana plugs but the spacing was wrong & it took me 2 or 3 tries to connect the wires to the binding posts. Bad design, Pioneer. Everything's fine now...
Erik The Pope
Erik The Pope
post #290 of 291 Old 08-10-2016, 10:01 AM
Quoted: 12 Post(s)
Liked: 3
Bass crossover slope for SC-71?
I've set my front speakers to small and the crossover to 80hz. Yet when I play music, extremely deep bass comes from both the fronts and the sub (well below 80hz). I'm using the NeoX mode for music playback, if that matters.
Anyone able to offer an explanation?
Zipadeedude is offline
post #291 of 291 Old 10-30-2016, 08:22 AM
jkkyler's Avatar
I have a question regarding supported resolutions. My video card is suposed to do 4k at 2160p and my tv is supposed to accept 4k@ 2160p but when I go to my control panel I only see the option for 4k@ 30p. Could this be due to going through this avr? I have the resolution set to "pure"
jkkyler is offline
Pioneer Elite Sc 71
