Should I get a 2ch amp - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 76 Old 01-23-2014, 11:50 PM
cableguy301's Avatar
Quoted: 75 Post(s)
Liked: 64
Originally Posted by lovinthehd View Post
d'oh....saw The Fugitive the other night. I make my own if you mean speaker wire with connectors, otherwise I just buy 14g speaker wire in bulk (usually 250 ft rolls so I don't need to do that very often), at the best price I can find....
  Connectors???   what kind of connectors???    you using tinned copper wire?   brass banana plugs?
      you like that high end 14awg cable from monoprice.com
         did you make some nice jumpers too?
cableguy301 is offline
post #62 of 76 Old 01-24-2014, 12:01 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
I use banana plugs in some cases, bare wire in others. Didn't buy from monoprice although would have, but found a nice clearance elsewhere on some basic 14g wire last time I needed to re-stock. Jumpers as in sweaters? No, don't knit, sorry. You'll need to explain what you meant by that one otherwise.
lovinthehd is offline
post #63 of 76 Old 01-24-2014, 12:32 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
He probably means the $100 per foot rca cables.
Just buy your cables/wire here and put a fancy label on them.
http://www.monoprice.com/Category?c_id=102
Or this is super high end.
http://www.bluejeanscable.com/
Bi-amp, bi-wire magic. $6 each
http://www.ebay.com/itm/Square-Recessed-Twin-Speaker-Quad-4X-Gold-Plated-Binding-Posts-for-sub-woofer-/250951876425
kikkenit2 is offline
post #64 of 76 Old 01-24-2014, 10:40 AM
Quoted: 75 Post(s)
Liked: 64
 jumpers   are used on 5way binding post...   the manufactures usually use gold plated brass..  so you remove this and use a nice
copper jumper.. or you can bi wire the 5 way post  with 14awg quad wire... perhaps your amp has 5 way binding post aswell..
  I personally like the 12 awg cable  just to have a little extra room in the pipe..
   better check out your speaker's jumpers mate!
post #65 of 76 Old 01-24-2014, 10:50 AM
Quoted: 75 Post(s)
Liked: 64
that last link has a good example of a low level jumper .... full of brass..  do you know what the conductivity of brass is relative to copper?
     that your binding post?
post #66 of 76 Old 01-24-2014, 11:07 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Why change the jumpers for wire? Other than looks, what would be the purpose? It will not affect sound at all.
jdcrox is offline
post #67 of 76 Old 01-24-2014, 11:27 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
No doubt copper conducts electricity better than brass, but that can be overcome by using a larger cross-section piece, and given the short length it doesn't matter anyhow.
arnyk is offline
post #68 of 76 Old 01-24-2014, 11:43 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
After I posted that I realized what you meant by jumpers. Regardless of how well they work I find them on cheap and expensive
speakers alike. Especially center speakers that have dual midrange drivers. Polk even puts them on cheap bookshelf speakers like
the monitor 30. It probably doubles their sales using those jumpers.
There may be brass inside those gold plated (thin for sure) jumpers. Why would they use brass? The only thing I know about brass is
it doesn't corrode/rust very fast. That is why brass is used for survey monuments.
I never remove jumpers. Why? I studied passive bi-amping a lot. Unless the crossover circuit board inside that box is designed to be
be bi-amped it is worthless. In fact sending massive power to tweeters is usually a bad thing. Most internal crossovers need to be bypassed
to improve performance. I trust the manufacturer to include a suitable jumper. If you want to improve that connection so be it. The only advice
I give out is don't remove that connection. Active bi-amping is a different story.
post #69 of 76 Old 01-24-2014, 11:46 AM
Quoted: 75 Post(s)
Liked: 64
   brass is about 28% the conductivity of copper  give or take because  different levels of impurities in the mixes...
   fe tin zinc cu   etc..
   yes a larger surface area will compensate for that..
    oh yes it matters it is resistance ... !
post #70 of 76 Old 01-24-2014, 12:02 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Look at the metal on the backside of the ebay link I posted. That looks like silvery potmetal
to me. The wire connecting the binding post to the crossover gets soldered on there. And
most of the other wires inside are super thin copper. Just like a chain. Where is the weakest link?
It is hidden from our eyes. Even most subwoofers have wimpy wires inside that box.
post #71 of 76 Old 01-24-2014, 04:49 PM
Quoted: 75 Post(s)
Liked: 64
best to replace your brass jumper to a copper one...
     don't want poor sound quality over a few pennies eh!
post #72 of 76 Old 01-24-2014, 04:56 PM
lovinthehd's Avatar
Liked: 4775
Yes, my avrs and most of my amps have 5-way posts but two pair of binding posts are not necessarily utilized on all speakers and not all speakers have jumpers accordingly, just those to placate those who feel that their bi-wiring/passive bi-amping are worth anything after reading silly reviews in audio magazines or "hearing" things about tweaks one can make....i.e. it's a waste of time and wire. Fortunately for my wallet my speaker designer didn't waste hardware money on silly bi-wiring/bi-amp posts and I have no plans to actively biamp my speakers in any case (but if I were to build my own speakers then I might want to play around with active bi-amping).
post #73 of 76 Old 01-24-2014, 05:12 PM
Troyd's Avatar
Quoted: 62 Post(s)
You're joking right?
Troyd is offline
post #74 of 76 Old 01-24-2014, 05:42 PM
Badouri's Avatar
Liked: 56
   get some big mono block amps from emotive xpr 1s will get those speakers singing real nice!
lovinthehd and 67jason like this.
Badouri is offline
post #75 of 76 Old 01-24-2014, 07:12 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
67jason likes this.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #76 of 76 Old 01-25-2014, 12:40 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Originally Posted by airgas1998 View Post
+1.
I don't need snobs to tell me how to think, thank you!
67jason is offline
Marantz Sr6008
