AVR-X1000 Reduce the height? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-27-2014, 02:17 AM - Thread Starter
Petsky's Avatar
Hi all,
I was wondering if the 4 feet can be removed from the chasis to reduce the Receivers height to fit into my cabinet.
I have 150mm available, size of receiver 151mm :(
Definately set my mind on this Denon AVR-X1000 one, or should I consider the Marantz NR1504 which has a reduced height?
Thanks for your replies!
Yves
Petsky is offline
post #2 of 2 Old 01-27-2014, 04:13 AM
jdsmoothie's Avatar
Quoted: 12119 Post(s)
Liked: 5517
Consider other placement as you want at least 3-4" clearance above the unit for sufficient ventilation.
Petsky likes this.
jdsmoothie is online now
Denon Avr X1000 5 1 Channel Home Theater Receiver
