bass and treble on Marantz sr 5005???? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-27-2014, 06:00 PM - Thread Starter
ermannolelli's Avatar
how can I low the bass coming out from the front speaker, either way pump a bit the trebles??
tks
ermannolelli is offline
post #2 of 5 Old 01-27-2014, 06:52 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
Do you have a subwoofer?
If so, adjust the crossover for the front speakers to 80hz and make sure the fronts are set to Small. That way the subwoofer will handle all the lower frequencies.
I guess I should ask what speakers you have?
Afro GT
afrogt is online now
post #3 of 5 Old 01-27-2014, 08:20 PM - Thread Starter
I do have a sub,  speakers brand Is KEF Q series, 50.
well when movies on and some music, the voice seems too deep, hard to understand sometimes.
So front an small instead of large, even if they do are large?
crossover front 80hz ok, what about central and surround?
I have central at 80 and surround 100 (I believe)
one more thing.
when I watch a movie, the best surround to be selected, is DTS Cinema, PLI Movie or just multi channel stereo?
the amp goes automatically on MCH stereo.
thanks for your help
post #4 of 5 Old 01-27-2014, 08:26 PM
afrogt's Avatar
Liked: 758
What source are you using to play your movies? DVD, Blu Ray, some type of streaming box?
KEF Q series 50 doesn't pop up anywhere. All five speakers are Q series 50?
Are they iQ50 towers? A little more clarification would help.
Afro GT
post #5 of 5 Old 01-27-2014, 09:56 PM - Thread Starter
~~What source are you using to play your movies?
DVD disc, usually using Pioneer bdp lx55, connected to the Amp by the BD channel.
YES
Marantz Sr5005 Audio Video Receiver Black
