Can't change Dynamic EQ in Denon 1912 - AVS Forum | Home Theater Discussions And Reviews
Old 01-27-2014, 07:40 PM - Thread Starter
smkHux's Avatar
Hi,
Weird question - for some reason when I go in to my menu and try to tinker with dynamic eq, i can't. I see it right before i click on audyssey settings, but then once i click that my only option is to change multeq from manual to off.
Is there a different place i should be trying this?
smkHux is offline
Old 01-27-2014, 07:42 PM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
Have you run the auto setup? You need to run it before audyssey and deq can be enabled.
primetimeguy is offline
Old 01-27-2014, 07:53 PM - Thread Starter
smkHux's Avatar
I did but it was a while ago. I think you must be right though because it's not coming up as an option.
The setup is when I use the microphone right?
smkHux is offline
Old 01-27-2014, 08:04 PM
Quoted: 556 Post(s)
Liked: 359
Correct
Denon Avr 1912 Receiver
