Trouble with Audyssey auto set up Denon 1910 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-29-2014, 08:07 AM - Thread Starter
jertronic's Avatar
Audyssey auto-set up is not working properly. When I start the Audyssey Auto Setup MultEQ with microphone connected the front left speaker chirps 3 times "Now measuring main listening position......." then I get a message "Microphone None or Speaker None" Retry or Cancel.
Isn't the setup supposed to cycle through the Left Ctr Right Surrounds and Sub? Any thoughts on troubling shooting my issue?
J
Jertronic -Denon Convert...long time Yamaha-head
jertronic is offline
post #2 of 4 Old 01-29-2014, 09:46 AM
Selden Ball's Avatar
Quoted: 3074 Post(s)
Liked: 1504
The receiver is telling you that it can't hear anything. If you can hear sounds coming from the speaker, then either the microphone or its connection are defective. Sometimes a piece of crud gets into the microphone socket on the receiver which can be blown out using a can of compressed air. Don't blow into it yourself: saliva is corrosive.
Selden
Selden Ball is online now
post #3 of 4 Old 01-29-2014, 10:14 AM - Thread Starter
jertronic's Avatar
I was able to get the set up to complete successfully. Thanks.
Now I have to fiddle with the settings on the blu ray player so HD audio signal comes through.
post #4 of 4 Old 01-29-2014, 10:18 AM
Liked: 1504
Great!
If you want the receiver to do the audio decoding, then there usually are two settings which have to be configured in the Blu-ray player: "Bitstream" on and "audio mix" off.
Selden
Denon Avr1910 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity
