New Audiophile - How do I choose an amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-02-2014, 05:50 PM - Thread Starter
MyronGanes's Avatar
Quoted: 16 Post(s)
I have a pair of 800 watt RMS @ 8ohms.
A lot of amps I see push much less than 800 watts @ 8ohms. Do I simply need a very high powered amp to be able to push RMS @ the 8 ohms?
MyronGanes is offline
post #2 of 4 Old 02-02-2014, 06:57 PM
Badouri's Avatar
Liked: 56
Are these the speakers? http://www.amazon.com/Podium-Pro-Speakers-Karaoke-E1525SET2/dp/B006GFO7WK
The tweeters on my Podium Pro 15DJD speaker have been damaged. I can't find the same replacement for them so it looks like I will have to put in different tweeters. The speaker is 8 ohm, 800 watt RMS 1600 max. What specs do I have to look for in a compatible speaker? It has to be the same resistance but how will a difference in wattage affect the speaker? I am new to speaker repair, thanks!
Badouri is offline
post #3 of 4 Old 02-02-2014, 09:11 PM - Thread Starter
MyronGanes's Avatar
Quoted: 16 Post(s)
post #4 of 4 Old 02-03-2014, 05:45 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
How much power you need depends on the size of the venue. The power rating is a maximum. it has nothing to do with what amp you need.
FMW is offline
