Best Setup Onkyo 626 - AVS Forum | Home Theater Discussions And Reviews
Old 02-06-2014, 08:25 AM - Thread Starter
ollyparkhouse's Avatar
Hi
I recently purchased my first ever AV system, and went straight in for the Onkyo 626 with the Q Acoustics 7000 5.1 series speakers.
So far loving it.
However I have noticed that on the Cbl/Sat the sound is very quiet compared with the other inputs. I put this down to the SKY HD+ box that is connected, but is there any way I can get the sound working on the same levels as my other inputs
PS3
PVR
Wii
etc
I have turned on the Dolby D setting over the HDMI but does appear to have made much difference.
any suggestions from anyone,
thanks
Olly
ollyparkhouse is offline
Old 02-06-2014, 09:39 AM
JChin's Avatar
Quoted: 308 Post(s)
Liked: 194
Hi ollyparkhouse, see Intellivolume setting found under Source Setup menu.
JChin is offline
Old 03-18-2014, 01:46 AM - Thread Starter
Hi thanks for the reply.
I have noticed that for some reason that when using the sky box the rear 2 speakers the audio quality is very poor. I have played around try to get the best audio output. changed from Game to Movie etc, and sometimes it works ok, but by default, I can barely hear much from the rears.
Could this be because some programs are televised using2.0 rather than 5.1 and thus the Onkyo tries to force it?
If I used the fibre optical output from the sky box, would that be a better setup,
Olly
Onkyo Tx Nr626 7 2 Channel Network Audio Video Receiver
taboola here
