Older Denon AVR-1082 & Connecting More Speakers To Another Room MULTI-ZONE? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-13-2014, 07:09 PM - Thread Starter
xboxmember1978's Avatar
Forgive me for the stupidness but I have been using this receiver for years and I only use it for normal 2-ch stereo mode, I have 1 pair of speakers hooked up to the "Front" section. I also have my powered sub hooked up too. I would like to have another set of Left/Right speakers in another room that will play the same audio/source that I play in the main room. Normally I would see a front speaker A & B hookup on a reciever but this one has what is called Multi-Zone. Is that the same thing? Will it work for what I want it to do?
xboxmember1978 is offline
post #2 of 10 Old 02-13-2014, 08:02 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Yes. Page 10 of the manual. Go into menu System Setup and select "Power Amp Assignment".
Change surround back to multi. There you go. Another set of front left/right speakers.
kikkenit2 is offline
post #3 of 10 Old 02-13-2014, 08:18 PM - Thread Starter
Thanks for the reply! Will the volume control turn up all 4 speakers at the same time? Or will the second set on Multi-Zone have a separate control? I hope the volume controls them together
post #4 of 10 Old 02-13-2014, 08:21 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
I'm pretty sure the volume controls both sets the same. You would
need a zone 2 feature for separate volume controls.
post #5 of 10 Old 02-13-2014, 10:13 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The 1082 is a multizone receiver. you can play different sources in each room. Straight from the product literature.
http://usa.denon.com/DocumentMaster/US/avr1082_productsheet.pdf
Afro GT
afrogt is offline
post #6 of 10 Old 02-13-2014, 10:28 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Oops. I'm so used to it called zone 2. That thing is old. So the volume's would be independent correct?
post #7 of 10 Old 02-13-2014, 10:39 PM
afrogt's Avatar
Liked: 755
Yep
Afro GT
afrogt is offline
post #8 of 10 Old 02-13-2014, 10:53 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
My initials are GT. And I was born near SF. Still a 49er/giants fan. I've never seen a receiver that had 3 sets
of surround without at least a speaker A & B or bi-amping. Now how to control the volume of that second zone?
post #9 of 10 Old 02-13-2014, 11:21 PM
afrogt's Avatar
Liked: 755
Here's the manual. Read pages 25 & 26.
http://usa.denon.com/DocumentMaster/US/AVR3802_1082_OwnersManual.pdf
Afro GT
afrogt is offline
post #10 of 10 Old 02-14-2014, 05:04 AM - Thread Starter
I don't have the second set of speakers yet, should be delivered next week or that I will test and mess around with it to see if it works, however I hope I can play the same source in both rooms and turn the volume up and have both sets of speakers turn up the same time
