Damsel in distress! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-14-2014, 02:36 PM - Thread Starter
sobouk's Avatar
Hi everyone
I have recently purchased a Philips Stereo Media Centre (901) from my local charity shop. It seems to work fine when playing through my headphones but the speaker outputs are like nothing I have seen before.
I think it's a specific plug/connector I need but I'm not sure.
Please see attached some pictures and please, any help is would be appreciated.
Thanks in advance!
Sophie
sobouk is offline
post #2 of 7 Old 02-14-2014, 02:50 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
From the other thread u started
http://www.ebay.com/itm/3-6-2mm-speaker-connectors-Sony-Samsung-LG-Philips-home-theater-Plasma-TV-6-2mm-/220848239666?pt=US_Audio_Cables_Adapters&hash=item336b94b432
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
post #3 of 7 Old 02-14-2014, 02:52 PM - Thread Starter
sobouk's Avatar
Thanks grasshoppers but these aren't the correct connectors.
sobouk is offline
post #4 of 7 Old 02-14-2014, 02:59 PM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 416
So are you missing the cables that goes from the main center part to the left, and right speakers?
DJoel
Djoel is offline
post #5 of 7 Old 02-14-2014, 03:04 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
I think you might have to look a bit closer at the suggested listing as there are "others" listed.... I think you need to find the spacing for your specific cables.
budwich is offline
post #6 of 7 Old 02-14-2014, 03:04 PM
Quoted: 802 Post(s)
Liked: 506
I can't seem to find any info on that unit!
You have a few options
1) try to contact Phillips directly. ( May be tough, unit seems quite dated)
2) take it back to the charity store.
3) take it to an electronic repair shop and see if they can help you out.
Rythmik F12 subs
post #7 of 7 Old 02-14-2014, 03:31 PM - Thread Starter
sobouk's Avatar
Budwich - I see what you mean but I contacted the eBay seller with photos and they said they don't sell these connectors.
grasshopper - yes it is quite old, early 1980s I think, so I may try taking to an electronic repair shop this weekend.
Thank you both for your help!
sobouk is offline
