Does the Yamaha RX-V773 have an optical output? - AVS Forum | Home Theater Discussions And Reviews
Old 02-17-2014, 05:22 AM - Thread Starter
stevenaive's Avatar
I'm thinking of buying a pair of Astro A50 headphones and it requires an optical connection.
My desired setup is, I want to be able to hear whatever sound the AV unit is outputting - whether it's source is the connected TV, PS4 or Xbox One.
Thanks in advance,
Steve
stevenaive is offline
Old 02-17-2014, 05:45 AM
Selden Ball's Avatar
Quoted: 3074 Post(s)
Liked: 1501
No it does not. See their specs summary at http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v773_black_u/?mode=model
Digital Audio Input/Output: Optical 2 / 0
Digital Audio Input/Output: Coaxial 2 / 0
In other words, two inputs of both types, but no outputs.
Also, don't forget that HDMI inputs are seldom transcoded by receivers to either optical or analog outputs. A few receivers, like the upper range models of Denon and Marantz, can output stereo analog to Zone 2 (or 3) from an HDMI input, but only if the input signal is stereo PCM, not surround-sound. In other words, you'd need to get an external HDMI-to-optical converter similar to this one: https://www.octavainc.com/HDMI%201x1%20Audio%20Converter.html
Selden
Selden Ball is offline
kenroj's Avatar
No it doesn't..
kenroj is offline
Old 02-18-2014, 02:14 AM - Thread Starter
stevenaive's Avatar
Ok, thanks for you're help guys. I figured as much, just wanted it confirmed. The Octava unit looks like just what I'm after, but a bit out of my price range.
I think I might look into getting an optical switch that I can plug the Xbox and PS4 into, I think they may be cheaper. I've seen this one on Amazon: http://www.amazon.co.uk/Lindy-TosLink-Digital-Optical-Switch/dp/B00517UMNW/ref=wl_it_dp_o_pd_nS_nC?ie=UTF8&colid=2UE1VUFRY6SUM&coliid=I3PDHF3URSNNAW
Yamaha Rx V773wa Receiver
