Receiver with pre outs for an amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 02-17-2014, 06:48 PM - Thread Starter
xxryan's Avatar
I have a denon e400 right now but it's not giving me the power I'm looking for for my cerwin vega ve15s so I need a receiver that has pre outs for an amp and is around the 1000 dollar range..any ideas on top receiver in this range..needs to have 7.1 also
xxryan is offline
post #2 of 44 Old 02-17-2014, 07:23 PM
postrokfan's Avatar
Quoted: 599 Post(s)
Liked: 3568
There are quite a few options in the $1000 range. I've listed some options below.
Yamaha RX-775WA
Yamaha RX-1030
Denon 3313CI
Marantz SR5008
Pioneer SC-71 (pre-outs for FR/FL only)
Also, I would consider refurbished units from accessories4less.com.
Living Room: B&W 804D2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is offline
post #3 of 44 Old 02-17-2014, 09:02 PM
Randall.White's Avatar
Quoted: 353 Post(s)
Liked: 89
Are you looking for preouts for 7 or just the L/R?
Randall.White is offline
post #4 of 44 Old 02-17-2014, 09:45 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
You also need to beware of the "supplemental" amp(s) that you plan on using along with the sound levels that you are trying to achieve... cause you may fall into the same problem others on the forum have with "AVR shutdown" as you may try to overdrive the pre-amp output stage for amps that are not that sensitive and the pre-amp don't have enough "poop".
budwich is offline
post #5 of 44 Old 02-17-2014, 10:08 PM
wvu80's Avatar
Quoted: 324 Post(s)
Liked: 292
Can you point me where to read on that, Bud? I don't mind doing the research, I'm just not sure where to look.
I have an Onkyo NR 717 125wpc, and a 5.1 speaker setup. My L/R SEOS Fusion 10 Pures are set for 10-300 wpc. I run a different center.
The Onk has pre-outs for amps, and I was wondering what the benefit would be of providing the L/R's with more power such as the Behringer A500 with 300 wpc, or something with more power (ie more headroom) such as the Behringer EP4000 at 550 wpc.
I currently get plenty of SPL. I was wondering if more power would = more punch or head room.
wvu80 is offline
post #6 of 44 Old 02-18-2014, 07:16 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1686
It might make your system more complicated and sexier. It would certainly improve your bragging rights.
FMW is offline
post #7 of 44 Old 02-18-2014, 06:13 PM - Thread Starter
xxryan's Avatar
I'm actually just looking to get an amp for my L/R fronts
xxryan is offline
post #8 of 44 Old 02-18-2014, 06:16 PM - Thread Starter
xxryan's Avatar
Burn out the pre amp out put?im confused on what I should do then? Get a stronger receiver and amp?
xxryan is offline
post #9 of 44 Old 02-18-2014, 06:44 PM
cinaibur's Avatar
Actually the Onkyo TX-NR717 is 110wpc. It's rated at 125 W (6 ohms, 1 kHz, 0.7%, 2 channels driven), 110 W (8 ohms, 20 Hz-20 kHz, 0.08%, 2 channels driven, FTC).
cinaibur is offline
post #10 of 44 Old 02-18-2014, 07:19 PM
wvu80's Avatar
Quoted: 324 Post(s)
Liked: 292
LOL! I know you're right! When you search for the specs, there is an entire paragraph about how much power into how many ohms into so many speakers, with every little variable. I can't keep it straight.
wvu80 is offline
post #11 of 44 Old 02-18-2014, 07:28 PM
Quoted: 353 Post(s)
Liked: 89
Ok, if you are only wanting to use an amp for your L/R. You can save quite a bit of money.
edit: Just looked up the receiver I had in mind and it's only 5.1
xxryan likes this.
post #12 of 44 Old 02-18-2014, 07:29 PM
cinaibur's Avatar
Sorry, not being a jerk. I just happened to be looking at that receiver today.
cinaibur is offline
post #13 of 44 Old 02-18-2014, 07:49 PM
wvu80's Avatar
Quoted: 324 Post(s)
Liked: 292
Never apologize for what you are.
Do I really need to put a smiley face on the above statement? Surely you know I took your comment in the fine, fine manner in which it was intended. biggrin.gif
wvu80 is offline
post #14 of 44 Old 02-18-2014, 08:43 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
I don't think I said you were going to burn out your receiver... I said it could "shutdown"... as most have protections in them to prevent overdriving stages.
AVR's are designed as a "complete system"... yes there are "hooks" to increase their flexibility but if you drive them towards "limits", then things like "shutdowns" happen. I suggested that you look at the specs of the amp you plan on using along with the SPLs you expect to achieve. IF you are pushing any of these, you will likely not be happy.
IF you want "seperates" AND "extremes", people then go the PRE-PRO route which does not contain any amps and are designed specifically to drive seperate amp stages.
budwich is offline
post #15 of 44 Old 02-19-2014, 04:57 AM
KidHorn's Avatar
Quoted: 1466 Post(s)
Liked: 963
Does your system have a subwoofer?
KidHorn is offline
post #16 of 44 Old 02-19-2014, 05:01 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
+1
From a sound quality standpoint adding a good subwoofer to a system that lacks one gives clearly audible benefits in terms of both bass extension (AKA ooompf) and dynamic range. This is generally a surer play than just an outboard amplifier.
arnyk is offline
post #17 of 44 Old 02-19-2014, 07:39 AM - Thread Starter
xxryan's Avatar
No I don't have a subwoofer..I know that would add a lot more extension to my system but it would also take up more room...but my options are somewhat open on that so I'll look into what would look good.
xxryan is offline
post #18 of 44 Old 02-19-2014, 07:41 AM - Thread Starter
xxryan's Avatar
And if I add a subwoofer wouldn't that change my fronts settings to "small"and take away a lot of bass up front?because then most low levels would be routed to the sub right?i don't know much on this it's just my guess.
xxryan is offline
post #19 of 44 Old 02-19-2014, 07:45 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Yes. But generally that's a good thing. Your speakers probably equal a good sub, although your CV have a 15" 26 Hz - 20 kHz, but at what -/+ figure? found -/+ 10dB. Pretty poor!
fatbottom is offline
post #20 of 44 Old 02-19-2014, 09:28 AM
cinaibur's Avatar
The Marantz 5007 is actually sold out. I ended up buying a Denon X2000 from them last night. It's going to stay in my living room setup, and I will upgrade everything when we buy a house and build a HT.
cinaibur is offline
post #21 of 44 Old 02-19-2014, 10:26 AM - Thread Starter
xxryan's Avatar
So you think I should look into buying a sub also? Or better front L/R speakers?
xxryan is offline
post #22 of 44 Old 02-19-2014, 10:29 AM
fatbottom's Avatar
Liked: 519
Both I'd start with a SVS SB1000 or PB1000 depending on room size
Cerwin Vega- eesh. I'd buy some new speakers too.
post #23 of 44 Old 02-19-2014, 12:09 PM
KidHorn's Avatar
Liked: 963
At a minimum, you need to add a sub, so start with that and see how it works out. if the sub is crossed over at say 80 Hz (A typical crossover value), it will take a lot of load off the receiver and give it more power to supply to the other speakers. Woofers require a lot more electricity than other drivers.
The 15" drivers in the fronts will handle everything from 80 Hz up in the sub area and should still get plenty of use.
KidHorn is offline
post #24 of 44 Old 02-19-2014, 12:11 PM
KidHorn's Avatar
Liked: 963
The SVS subs are a good choice for around $500. I would get the ported one over the sealed.
KidHorn is offline
post #25 of 44 Old 02-19-2014, 12:40 PM
fatbottom's Avatar
Liked: 519
Why is that?
I've gone from Ported to Sealed.
Just depends on room size, and preference.
post #26 of 44 Old 02-19-2014, 01:10 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
A sub was my suggestion in his other thread http://www.avsforum.com/t/1518081/bass-problem-with-cerwin-vega-ve15f-and-denon-e400
lovinthehd is offline
post #27 of 44 Old 02-19-2014, 01:42 PM
jontyrees's Avatar
Liked: 38
I like Cerwin Vega. To each his own.
jontyrees is offline
post #28 of 44 Old 02-19-2014, 01:45 PM
jontyrees's Avatar
Liked: 38
set them to "small", even though they are actually huge, and set the crossover low, like 50hz. Or your receiver might have a setting like "plus" for the sub which would let the bass go through both your fronts and the sub.
post #29 of 44 Old 02-19-2014, 02:05 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Bass is notoriously non-directional below the usual 80 Hz crossover so the actual location of the subwoofer(s) does not seriously detract from the bass at the front of the room.
In that range good subwoofers dramatically outperform even the largest allegedly full-range speakers in the area of bass extension, dynamic range and low distortion. Basic bass power is based on the product of cone area and linear cone displacement. 12-13" subwoofer drivers can have up to 25 mm linear travel, whereas even the larger and more robust woofers have less than-9 mm linear travel, while few have 12" cones with 6.5 inch being pretty common. An 18" subwoofer has about twice the cone area as a 12 incher and many people have more than one subwoofer.
arnyk is offline
post #30 of 44 Old 02-19-2014, 02:09 PM
fatbottom's Avatar
Liked: 519
PA gear go loud...that's about it.
Denon Avr E400 , Yamaha Rx V775wa 7 2 Channel Network Av Receiver , Yamaha Aventage Rxa 1030 Receiver , Denon Avr 3313ci Receiver , Marantz Sr5008 , Pioneer Elite Sc 71 , Onkyo Tx Nr717
