Denon Volume - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-18-2014, 07:57 AM - Thread Starter
nolatravelgirl's Avatar
Forgive me for maybe sounding like a newbie. I just purchased a Denon AVR-X1000 and Energy Take Classic speakers. I am concerned that I maybe did something wrong while setting them up. The set up is in a medium sized living space and the sound goes from 0-99. I have it set at 60 and it isn't all that loud while just watching regular TV programming. Is there some setting I should be checking?
nolatravelgirl is offline
post #2 of 8 Old 02-18-2014, 08:00 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
That's normal. It should be getting loud at -20dB. I assume you ran the calibration?
fatbottom is offline
post #3 of 8 Old 02-18-2014, 09:44 AM
tezster's Avatar
Quoted: 514 Post(s)
Liked: 394
As part of the Audyssey calibration, it asks if you want to enable Dynamic Volume. The default level it uses is Medium if you enable it, make sure to change this to Light or turn it off entirely if broadcast TV doesn't sound loud enough. Also, many channels only transmit stereo/2-channel dolby digital, which will naturally affect how many speakers are used, and how loud you perceive the content.
tezster is offline
post #4 of 8 Old 02-18-2014, 09:57 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 104
The way her's is set up, it is reading positive numbers, it will never show her "-20dB". I do believe you can change this in the setup menu however.
jdcrox is offline
post #5 of 8 Old 02-18-2014, 10:24 AM - Thread Starter
Thanks, I need to go get a new cable for the subwoofer, so I will try to recalibrate this evening and see if things improve.
post #6 of 8 Old 02-18-2014, 10:39 AM
jontyrees's Avatar
Liked: 38
Turning it up past 60 won't hurt it, it probably has one of those non-linear volume scales where the difference between 40 and 60 is nowhere near the difference between 60 and 80. Turn it up if you want it louder.
Also - did you run the Audyssey eq program to set levels, eqs, crossover points, etc? It may have set very low levels on the different channels - you can go in and bump them up manually if you want more volume at a lower point on the display's volume scale. You don't have to take what the machine gives you - it doesn't know your tastes!
jontyrees is offline
post #7 of 8 Old 02-18-2014, 02:48 PM
jdsmoothie's Avatar
Quoted: 15054 Post(s)
Liked: 7263
Actually, Dyn Volume will produce louder dialogue as lower master volume levels, so the OP should likely leave it set at the default setting of ON/Medium.
jdsmoothie is offline
post #8 of 8 Old 02-18-2014, 02:52 PM
jdsmoothie's Avatar
Liked: 7263
After Audyssey has been run, 80 is considered movie reference volume, a master volume level you generally should not exceed to ensure the AVR has enough headroom and won't shut down in protection mode. Generally 50-70 is average movie/music listening and 40-60 is average TV listening. Your best bet is to set Dynamic Volume ON/Medium as I noted previously for TV listening.
Also note there is a whole thread dedicated to just the Denon 2013 models ... review posts #3-6 for additional helpful information to include what the firmware updates include.
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23134210
Denon Avr X1000 5 1 Channel Home Theater Receiver , Energy Take Classic 5 Pack 5 0 Home Theater Speaker Black
