Question about volume level on Denon AVR 1912 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-19-2014, 07:09 AM - Thread Starter
Timeee's Avatar
On my 7.1 Denon AVR 1912, I seem to have to have the volume turned up quite considerably for the audio to be loud enough... The audio also shows up as neg decibels (is that standard?). I've adjusted the channel levels to their highest levels now, which has helped, but that seems a bit janky considering that the levels are supposed to be set by distance needs and now are all just set high. I'm not saying the sound is bad, because it isn't, it just seems a bit counterintuitive to me. Any ideas, thoughts or comments to edify me better?
Timeee is offline
post #2 of 6 Old 02-19-2014, 07:25 AM
Socketman's Avatar
Quoted: 162 Post(s)
Liked: 170
what speakers
Socketman is offline
post #3 of 6 Old 02-19-2014, 07:27 AM - Thread Starter
Timeee's Avatar
Timeee is offline
post #4 of 6 Old 02-19-2014, 07:27 AM - Thread Starter
Timeee's Avatar
Denon AVR-1912 7.1 Channel A/V Home Theater Receiver and Polk Audio 5.1 TL1600 Speaker System
Timeee is offline
post #5 of 6 Old 02-22-2014, 05:09 AM
jdsmoothie's Avatar
Quoted: 14555 Post(s)
Liked: 6911
There are two volume scales that can be used (0-99 or -78db to +18db) both of which are logarithmic in that the volume will not get loud until you approach the 2/3 - 3/4 point. You are using the second scal in which the volume level negative number decreases as the volume approaches movie reference volume or 0db. The average listening level is -40db to -20db for TV listening and -30db to -10db for movie watching. Restore the Audyssey Auto settings and you should be good to go.
jdsmoothie is offline
post #6 of 6 Old 02-22-2014, 06:04 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
It may surprise many but one of the things that one learns on the test bench is that a lot of amplifiers actually work best when their volume controls are maxed out. That may or may not relate to your situation but the take away is that running the volume control turned clockwise a lot has no actual adverse effect on sound quality. Cranking the channel trims generally costs you nothing SQ-wise. if you feel that the AVR is working harder because the volume control is up so high, its something that you perceive that has no reality outside of your brain. Playing your speakers loud makes the AVR work harder but how you get there is not important.
The best advice seems to be is to make sure that your system is optimized, using the automated tools that the AVR probably has built in, unless you know better, and about the only way you know better involves analytic software like REW a relatively inexpensive USB measurement-type microphone and spending some time climbing a learning curve that many have climbed and benefited from.
arnyk is offline
Denon Avr 1912 Receiver , Polk Audio Tl1600 Speaker System
