Pioneer Elite SC-79 or Denon AVR-4520CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-19-2014, 01:20 PM - Thread Starter
mantaraydesign's Avatar
Quoted: 167 Post(s)
Liked: 35
I am looking at these 2 latest receivers from Pioneer and Denon. Which receiver will have a better choice for music as well as movies?
I do listen to a lot of 2 channel SACDs and regular CDs. So which receiver will have a better amp for music?
But once in a while, I do watch movies.
mantaraydesign is offline
post #2 of 4 Old 02-20-2014, 09:52 AM
Jon S's Avatar
Quoted: 928 Post(s)
Liked: 303
Best bet is to listen to both units at a dealer... Everyone has different opinions...
Mine? Denon is more musical but the Pioneer has more dynamics... Pioneer has better DACs, their class D amps are more powerful and can handle 4-ohm loads. The Denon has better auto EQ, better remote,
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #3 of 4 Old 02-20-2014, 09:55 AM
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
I would get the Denon since Audyssey XT32 with dual sub calibration is far superior to MCACC. The amps will sound the same and their power is about the same.
KidHorn is offline
post #4 of 4 Old 02-25-2014, 06:28 AM
graphicguy's Avatar
OP....don't know if you decided on anything yet. But, I've owned multiple Pioneer Elite SC AVRs and currently have a Denon 4311 (predecessor to the 4520).
Really, you can't go wrong with either. They both sit at the very top tier of any AVR, from any manufacturer, at any price.
As was pointed out, the Denon uses XT32, which I find works very well, particularly given my 2 subwoofer layout. That said, my experience with Pioneer's SC series really points out how well they do the amp sections of their top end AVRs. They are really dynamic and, for lack of a better term, "smooth" sounding. They will take a bit of tweaking given MCACCs stubborn lack of subwoofer room correction, but it can be done. One caveat, not sure what version of MCACC Pioneer is now using. The last experience I had with MCACC was probably a couple of years ago. But, they don't change it all that often.
No bad choices here. Good luck!
Music so high you can't get over it....music so low you can't get under it!
graphicguy is offline
Pioneer Sc 79 , Denon Avr 4520ci Receiver
