Using Powered Zone 2 with Multi-Zone splitter - AVS Forum | Home Theater Discussions And Reviews
Old 02-21-2014, 02:14 PM - Thread Starter
Dashome's Avatar
My current setup includes a Marantz SR5007 with a 2.1 speaker configuration in my main room.
I want to add the following:
-2 speakers in master bath (planning on using 2x Klipsch R-1800-C)
-2 zones of 2 speakers (one in covered front porch, one in back)
-2 speakers in the garage
I was wondering if using something like a Niles-S4 splitter would be okay or if I should configure zone 2 to be controlled by the SR5007 and use the preout to a 4 zone triggered amp. If so, what affordable amp options would be sufficient?
For the porches, could I use Klipsch R-1800-C outside or should I stick with a dedicated outdoor speaker? Between ceiling or wall mount outdoor speakers, which one is a better option?
Dashome is offline
Old 02-21-2014, 07:39 PM
jdsmoothie's Avatar
Quoted: 12103 Post(s)
Liked: 5508
For background level volume only you might get away with connecting the Niles to the Zone 2 speaker posts, otherwise another option is to connect the Niles to a 2CH amp connected to the Zone 2 pre-outs.
Dashome likes this.
jdsmoothie is offline
Old 02-24-2014, 11:35 AM - Thread Starter
Dashome's Avatar
Thanks for the input. If I wanted occasional louder music in 3 zones split by the Niles heading to 50 watt RMS 8 ohm speakers, what minimum amp specs should I be considering? Is 200w RMS/channel at 8 ohms sufficient? 70V transformers would not be needed for this setup, correct?
Dashome is offline
Old 02-24-2014, 04:03 PM
jdsmoothie's Avatar
Liked: 5508
Old 02-24-2014, 07:08 PM - Thread Starter
Dashome's Avatar
I found a great deal on a Crown xps1500. Guessing that should get the job done too with a 4 ohm speaker setup?
Dashome is offline
Old 02-24-2014, 07:13 PM
jdsmoothie's Avatar
Liked: 5508
Marantz Sr5007 Home Theater Av Receiver
