NR929 vs X4000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-24-2014, 07:37 AM - Thread Starter
scotsman8's Avatar
Quoted: 12 Post(s)
I can't make the decision between these 2 receivers on which to buy. I am doing DIY Alpha-8 Minion for L/R and waiting on the MTM version for the center, also once I build the Alpha-8's I will decide whether I will build 4 more for surround duty or go with something a bit smaller for 7.1. I will have 2 subs and from what I have read that would be better to have the X4000, but they will be powered by an iNuke 6000DSP. Does that mean the receiver would not be doing any of the sub function and the inuke would be, or should i still go for the x4000?
scotsman8 is offline
post #2 of 10 Old 02-24-2014, 09:53 AM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
The X4000 can set different distance and sound level trims for its two subwoofer outputs. The NR929 can't.
Edited to add: the DSP has "dual mono" mode, which processes each speaker channel completely separately from the other, so you can take full advantage of the X4000's dual subwoofer outputs.
Audyssey and external DSPs can work fine together. You just have to decide if you want to use the DSP to process the audio before or after Audyssey does.
If you calibrate the DSP before Audyssey, the DSP can be used to minimize obnoxious peaks so that Audyssey otherwise would struggle with. If you calibrate the DSP after Audyssey, it might be able to fill in the peaks and valleys that Audyssey leaves behind.
Of course, you'll need an external spectrum analyzer to find out which procedure works best in your acoustic environment, perhaps either OmniMic or REW. See http://www.avsforum.com/t/1449924/simplified-rew-setup-and-use-usb-mic-hdmi-connection-including-measurement-techniques-and-how-to-interpret-graphs
Selden
Selden Ball is offline
post #3 of 10 Old 02-24-2014, 12:27 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
I would avoid Onkyo... They have not been very reliable over long term... There's a lot of issues with them failing... HDMI boards being the primary cause.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #4 of 10 Old 02-24-2014, 02:07 PM - Thread Starter
scotsman8's Avatar
Quoted: 12 Post(s)
Thats what I hear people say, but I've had an Onkyo NR807 in my living room for about 4 years without a single problem. Regardless I went ahead and ordered the X4000 anyways.
post #5 of 10 Old 02-24-2014, 02:21 PM
jdsmoothie's Avatar
Quoted: 12094 Post(s)
Liked: 5503
Be sure to review posts #3-6 in the 2013 Denon E/X Owner's thread for helpful information on your new AVR.
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23134210
scotsman8 likes this.
jdsmoothie is online now
post #6 of 10 Old 02-25-2014, 10:40 AM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
I had three Onkyos, two 905s and a 906... All three failed...
Jon S is offline
post #7 of 10 Old 03-23-2014, 01:29 PM
MarkGierke's Avatar
I would avoid making generalizations here. The TX-NR929 has not experienced the HDMI board issues as far as I have heard and it seems to run substantially cooler than its predecessors.
MarkGierke is offline
post #8 of 10 Old 03-23-2014, 04:01 PM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
True, but they are having some issues with no video and only sound... Also some amplifier failures.
Jon S is offline
post #9 of 10 Old 04-26-2014, 06:54 AM
yadfgp's Avatar
Quoted: 66 Post(s)
Liked: 68
I owned an 818 for about 18 months and currently have a 929 for about 8 months now and never had an issue with either one.
I also owned a couple of Denons before those and they were great AVR's but seemed over priced to me.
yadfgp is offline
post #10 of 10 Old 11-18-2014, 12:25 PM
Lttrader's Avatar
Quoted: 13 Post(s)
Liked: 27
Well after a year of everyday use, my TX-NR929 continues to perform flawlessly. I couldn't be more pleased.
Lttrader is offline
Denon Avr X4000 7 2 Channel Home Theater Receiver , Onkyo Tx Nr929 9 2 Channel Network A V Receiver
