Denon 3312CI vs refurbished Denon AVRX4000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-24-2014, 11:01 AM - Thread Starter
leveille's Avatar
I recently had to have my 3312ci looked at for repair. The repair facility decided it wasn't worth fixing or too costly, so they referred it back to Denon for a suitable replacement. I was just recently contact by Denon and told that I will be receiving a refurbished AVRX4000 for my replacement. I have never heard of this model before, and I am not really versed on the newer Denon products or lineup. Is this considered a suitable replacement for my 3312ci? Any suggested readings on the differences between my old AVR and this one, or any information about the two and their differences would be appreciated. Thanks!
leveille is offline
post #2 of 5 Old 02-24-2014, 11:12 AM
fdefulvio's Avatar
From Denon's site under "News" there is an announcement of their IN-Command receivers:
Previous Model New Model
AVR-1913 E-Series AVR-E400
AVR-1613 E-Series AVR-E300
AVR-1513 E-Series AVR-E200
AVR-3313CI IN-Command AVR-X4000
AVR-2313CI IN-Command AVR-X3000
AVR-2113CI IN-Command AVR-X2000
AVR-1713 IN-Command AVR-X1000
There may be a few differences in features, but the X4000 gets mostly very favorable reviews.
fdefulvio is offline
post #3 of 5 Old 02-24-2014, 12:01 PM
NK215's Avatar
The X4000 is very close to the 4311CI receiver. In other word, it's in a totally different league from your 3112.
Denon officially replaced the 4311CI with the 4520CI however both the 4520 and the X4000 have XT32 which is where the real beef is.
NK215 is offline
post #4 of 5 Old 02-24-2014, 01:04 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 972
You definitely got an upgrade as the x4000 uses Audyssey XT32 with HT Sub EQ. The Sub EQ lets you calibrate two separate subwoofers.
Your 3312 uses Audyssey MultEQ XT which has far less filter resolutions than XT32.
http://www.audyssey.com/technologies/multeq/flavors
Afro GT
afrogt is offline
post #5 of 5 Old 02-24-2014, 01:26 PM
jdsmoothie's Avatar
Quoted: 15074 Post(s)
Liked: 7274
jdsmoothie is online now
Denon Avr X4000 7 2 Channel Home Theater Receiver , Denon Avr3312ci Receiver , Denon Avr E400 , Denon Avr E300 , Denon Avr E200 , Denon Avr X3000 7 2 Channel Home Theater Receiver , Denon Avr X2000 7 1 Channel Home Theater Receiver , Denon Avr X1000 5 1 Channel Home Theater Receiver , Denon Avr 4520ci Receiver , Denon Avr 2113ci Receiver , Denon Avr 2313ci Receiver , Denon Avr 1713 Receiver , Denon Avr 3313ci Receiver
