Open floorplan Denon X4000 Def Tech 8060 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-24-2014, 01:01 PM - Thread Starter
Shicks2's Avatar
I have a open gameroom/cinema in my basement about 30 x25. I have the theater part at the end of the room with risers for the second row of chairs. So it has 3 walls surrounding it the other is open to the bar/gaming area. I have a Denon X4000 receiver with 8060 def tech towers, 8080 center and surrounds. I also have a SVS sb13 ultra sub. I know the open concept is not ideal for audio purposes, but I like the openness of the current set up. I have experimented with many different setups in the av and currently have everything set to small with a 80 crossover. I have to turn the sub up almost all the way to get any sort of kick during movies and the speakers are certainly "loud" enough, but not as crisp and the system doesn't sound as tight as I think it should. Because of the size and openness of the room, do I need more power to the speakers and do I need dual subs? Thank you for the help audio gods
Shicks2 is offline
post #2 of 3 Old 02-24-2014, 03:12 PM
jdsmoothie's Avatar
Quoted: 12174 Post(s)
Liked: 5547
Rather than making the adjustment on the sub, it should be set to about 9 o'clock which should result in the AVR setting the sub channel to somewhere between about -6db and 0db after running Audyssey which you can then boost using the AVR's Subwoofer Level setting +3-5db to suit your preference.
jdsmoothie is offline
post #3 of 3 Old 02-24-2014, 03:18 PM
Kini62's Avatar
Quoted: 1421 Post(s)
Liked: 1308
The sb13 while a superb sub is just not the right sub for that large of a room. A pair of large, ported subs is what is likely needed if you want to feel the bass.
As for the speakers, distance to the listening position is what you should be looking at, not room size. For the sub the entire volume needs to be factored in though.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Denon Avr X4000 7 2 Channel Home Theater Receiver , Definitive Technology Bp8060st Supertower System , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Definitive Technology Cs 8080hd Powered Subwoofer Center Channel
