What is the calibration tone frequency used by the AVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-26-2014, 04:13 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
I have a 3 db difference between my REW mic/SPL meter (with sensitivity data added to the cal file) and the rat shack meter when trying to set the proper speaker sound level.
I'm wondering if the rat shack needs correction applied. ?
pdxrealtor is offline
post #2 of 8 Old 02-26-2014, 04:18 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Google on Radio Shack SPL meter calibration
However, the sensitivity of the mics used in cheap SPL meters and low cost measurement-type mics is well known to be inaccurate and change based on weather, temperature, etc.
If you pay the big bucks (e.g $600+ for the mic it might be reasonable to expect something better)
arnyk is offline
post #3 of 8 Old 02-26-2014, 04:19 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Yes, I did Google and that's when I realized I have no idea what frequency the AVR is putting out when setting the speakers to 75db.
post #4 of 8 Old 02-26-2014, 04:45 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If your AVR is calibrated by Audyssey, it uses a chirp or sweep. so the full audio band is involved.
arnyk is offline
post #5 of 8 Old 02-26-2014, 04:46 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
So which one would you use to double check the job the receiver did at setting levels?
post #6 of 8 Old 02-26-2014, 04:47 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
It's Pioneer MCACC, and for channel level it uses a 'noise' tone. THat's why I'm having the issue with the correction file.
post #7 of 8 Old 02-26-2014, 06:13 PM - Thread Starter
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
post #8 of 8 Old 02-27-2014, 02:18 PM
Happy Tom's Avatar
Arny? Anyone??
Test tones are typically "White Noise" meaning that all audible frequencies are input simultaneously and at the same amplitude.  If the two mics differ by 3 db, that is a relative difference, an offset. As long as the difference remains 3 db on all channels, the system would be properly balanced, yes?
Happy Tom is offline
