Panasonic VSX-523K Sound Quality Issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-28-2014, 08:20 AM - Thread Starter
Uriarte69's Avatar
I have a brand new VSX-523K hooked up to a projector with HDMI. I'm running a PS3 and a Comcast HD box both through HDMI to the receiver. It is connected to a 5 speaker system with a subwoofer. Some shows come across sounding perfect - others come across sounding like they're at the bottom of a tin can for lack of a better term. I've even had the show sound fine, and the commercial sound bad. I guess you could all it an echo, although the sound doesn't really repeat - it just awful quality. I've used the MCACC for setup, and verified that everything it set up was correct. Changing from a preset option like Action or Drama to stereo reduces the "echo", but eliminates the surround sound. I have the issue no matter if I'm watching cable or a video on my PS3 - Any ideas?
I didn't have a problem with the old receiver (until it died) which was setup as follows - same cable box - component. PS3 - Digital Audio. Everything was run to the projector seperately for video. All speakers are the same.
Uriarte69 is offline
post #2 of 3 Old 02-28-2014, 08:25 PM - Thread Starter
Uriarte69's Avatar
I've determined that HD channels sound fine - standard channels produce the echo. When I switch to auto the echo is gone- I get sound out of the front speakers, but no surround sound.
post #3 of 3 Old 03-03-2014, 03:14 AM
The_BladeDTS's Avatar
I'm curious try one of the following
1) Set S.DELAY to a higher number i.e 1.0
2)Set surround speakers as large even if they aren't
3)Set subwoofer distance to one inferior than your furthest speaker
example: right speaker at 3.0 meters put sub distance at 2.0 meters
The_BladeDTS is offline
Pioneer Channel Av Receiver Vsx 523 K
