Pioneer SC72 or Denon X4000 for Klipsch RF-7 II's? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-03-2014, 12:03 PM - Thread Starter
mvedepo's Avatar
I am looking at a package and would like some input. The complete package includes:
2 x RF-7II Towers
1 x RC-64II Center
2 x RS-62II Surrounds
2 x BIC Acoustech PL-200
1 x Each Denon AVR-X4000 or SC72
Will the x4000 or SC72 be enough for this setup?
Thanks in advance!
mvedepo is offline
post #2 of 10 Old 03-03-2014, 01:12 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 9750 Post(s)
Liked: 4533
Klipsch speakers are extremely easy to drive with any AVR.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
post #3 of 10 Old 03-04-2014, 08:58 AM
asharris7's Avatar
If you are going high end like that, the speakers would appreciate an amp like the Outlaw 7500 at 200 wpc x 5.
asharris7 is offline
post #4 of 10 Old 03-04-2014, 02:01 PM
Kini62's Avatar
Quoted: 1141 Post(s)
Liked: 1068
A less expensive AVR and a better sub will make more difference.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
post #5 of 10 Old 03-04-2014, 02:18 PM
asharris7's Avatar
Yes, that's true too. I would get at least a PB 12+ If you get a less expensive AVR with pre-outs, and an external amp, you should be set.
post #6 of 10 Old 04-04-2014, 10:57 PM
Fastslappy's Avatar
Liked: 749
go with the Pioneer those new Class D ICE amps are way better & they keep the watts per channel higher than that Denon ever will when running 5 or more speakers
Look at this rig
http://www.amazon.com/dp/B00DQHZYRI/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2N9S098UA2A1B&coliid=I29GKHQRLNNFCI
or this one
http://www.amazon.com/gp/product/B00D4MQ0UU/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1
these go on gold box deals every so often
I got the 1325 for $600.oo weeks ago
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #7 of 10 Old 04-04-2014, 11:32 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4533
The X4000 has more than enough power for that speaker setup and takes the nod on subwoofer EQ using Audyssey MultEQ XT32 which can EQ the subwoofer and also has Audyssey Sub EQ HT (dual sub level/delay calibration) and comes with a 3 year warranty vice only 2 years on the Pioneer. If you plan on connecting a Zone 2, the X4000 can also route an independent HDMI PCM 2.0 signal to Zone 2 and optical/digital coax PCM 2.0 to Zone 3 as well.
post #8 of 10 Old 05-26-2014, 06:03 PM
DaJoJo's Avatar
Quoted: 354 Post(s)
Liked: 782
hmdi won't go any further then 10 meters unless it has a signal-booster between the cable. some do 15 meters but only thin wire cable will do 1080P on them and no 4k , so it renders zone stuff useless as these signalboosters are expensive. for the 400 u pay more on the denon you could get a nice svs sub and level the bass way better then any audyssey sub eq will be able to do.
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
post #9 of 10 Old 05-26-2014, 07:01 PM
585-645-1006
jdsmoothie's Avatar
Liked: 4533
Audyssey Sub EQ HT would more likely do a much better job than any manual solution. Also Monoprice 50' cables as well as Redmere 65' cables are both known do work quite well with any additional amplification.
post #10 of 10 Old 05-26-2014, 07:07 PM
DaJoJo's Avatar
Quoted: 354 Post(s)
Liked: 782
2 good subs would do nicely too. i find any audyssey but pro version lacking and alter the original sound to much, probably me.. 50' will get me as far as the other side of the livingroom... it does 4k ?
but on-topic.. both avr will have enough power to get the klipsch going.. more power will make em sound even better.
DaJoJo is offline
Denon Avr X4000 7 2 Channel Home Theater Receiver , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Pioneer Elite Sc 72 , Bic Pl 200 Acoustech Platinum Series Subwoofer , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Black Each , Klipsch Rf 62 Ii Reference Series Floorstanding Loudspeaker , Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer
