Can someone help me out with 2-channel listening modes on Onkyo TX-NR818? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-04-2014, 05:19 PM - Thread Starter
rohfan2112's Avatar
Just bought an 818 from a member on another forum and I don't want to keep pestering him with questions so I'm asking here.
I cannot figure out how to listen to a CD in Stereo mode (or 2.1). I would want Audyssey active as well. It seems like everything is stuck in THX surround modes. I also can't figure out how to set the receiver to "auto" decode so it sets itself based on the incoming signal. I have searched the message boards and I can't believe I cannot find a simple explanation to this. The manual is, naturally, no help.On my previous Marantz and Denon AVRs they had an "auto" button that performed that function. Thanks in advance if anyone can help me out.
rohfan2112 is offline
post #2 of 5 Old 03-04-2014, 07:59 PM - Thread Starter
rohfan2112's Avatar
Just figured it out. I was playing around with the 818 for some time and the clouds suddenly lifted and I was at one with the Onk.
post #3 of 5 Old 03-05-2014, 04:53 AM
Ray77085's Avatar
Quoted: 131 Post(s)
Liked: 159
Great that you figured it out. Post up on how you were able to figure it out so if others have the same issue, then the question would be already answered.
MY 7.4 SET UP.
Onkyo TX-NR809, Denon X4200 (Klipsch-KF-28 mains),( Center KC-25), (Front wide- Primus P363), (AR-Stature S20 side surrounds).2 each Klipsch RW12D subs. HSU VTF-3 MK3 and HSU VTF-3 MK4 subs.
Mitsubishi 3D DLP MODEL73-738, DarbeeVision DVP-5000.Pioneer BDP-62FD.
Ray77085 is offline
post #4 of 5 Old 03-05-2014, 05:41 AM
wtxgringo's Avatar
Quoted: 50 Post(s)
Liked: 63
Home button > Setup > Unlocked > Listening Mode Preset where you can set all your listening preferences for bdp, cdp, tv, phono etc! biggrin.gif
"To the journey..."
Sony KDL60W630B; Onkyo TX-NR818
Polk RTi A7 Mains; Polk RTi CSi A6 Center; Polk RTi A5 Wides & Surrounds
HSU VTF2-Mk4, Dish Network 722k, Iogear WiFi Hub
Teac PD-H600; Marantz BD7004;
Orbit TT Red Plinth, Acrylic Platter, Ortofon OM 5E Cartridge
wtxgringo is offline
post #5 of 5 Old 03-05-2014, 07:49 AM - Thread Starter
rohfan2112's Avatar
That's what I was doing but couldn't figure out how to make the change stick. Upon subsequent tries I noticed that Onkyo's GUI on the bottom right of my TV screen said "ENTER to choose," or something like that. That was my mistake...I was scrolling through the options but never activated them by hitting "enter." The reason I didn't see it at first was that the GUI's overlay is transparent and I didn't notice the text on the bottom due to the channel I happened to be watching at the time. It just got "camouflaged." That's my story and I'm sticking to it! smile.gif Now I just have to figure out how to assign my favorite settings to the remote.
Onkyo Tx Nr818
