My Pioneer Elite VSX_92 or new AVR?? - AVS Forum | Home Theater Discussions And Reviews
Old 03-06-2014, 08:14 AM - Thread Starter
bebop86's Avatar
Just pulled my vsx-92 from the closet to hook up a 5.1 system in my family room- Is there anything that I am missing using this unit VS getting one of the new hi-end AVR's that are out there- Mostly concerned about sound quality- thanks
bebop86 is offline
Old 03-06-2014, 09:11 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1686
No difference in sound quality. The newer models will have the latest Dolby and DTS codecs and the ability to connect directly to the internet. Otherwise, you have a higher quality unit than the major manufacturers make today. I use a VSX-92 myself. I have no motivation at all to put anything new in its place. i don't think the latest codecs are all that important and I don't connect my system to the internet. Nevertheless, my Blu Ray player has that capability. Enjoy the fact that you have an outstanding AV receiver.
FMW is offline
Old 03-06-2014, 09:41 AM
jrhooper1963's Avatar
Quoted: 56 Post(s)
Liked: 36
Others on this forum may beg to differ, but I wouldn't "upgrade" the receiver. I would consider a speaker upgrade...... if anything.
jrhooper1963 is online now
Old 03-06-2014, 09:45 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 376 Post(s)
Liked: 258
Room correction improvements will easily make the biggest difference in perceived sound quality. If you're using and happy with the results from Advanced MCACC in your Pio, you're golden. If not, I'd consider one of the Audyssey XT32 products, or wait for user reports about the forthcoming Emotiva XMC-1. If Emo gets it right, their inclusion of Dirac could set a new bar for room correction in a consumer AVR.
RUR is offline
Old 03-06-2014, 09:52 AM
FMW
FMW's Avatar
Liked: 1686
If we are going to consider DSP then I would say no meaningful difference in sound quality. Any differences would be subtle at best.
FMW is offline
Old 03-06-2014, 09:56 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 376 Post(s)
Liked: 258
If we consider Room Correction products - MCACC vs. some others - I would say (and so would the research) that there are distinct i.e. not subtle differences in sound quality. Are we going to go down this road, again?
RUR is offline
Old 03-06-2014, 09:58 AM
FMW
FMW's Avatar
Liked: 1686
Not if you don't want to. it is just semantics. One person's huge is another person's subtle. Sound differences can be subtle and distinct at the same time, can't they?
FMW is offline
Old 03-06-2014, 10:06 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 376 Post(s)
Liked: 258
I doubt that objective readers would find the below FR differences in comparison of RC products to be "subtle".
https://docs.google.com/file/d/0B97zTRsdcJTfY2U4ODhiZmUtNDEyNC00ZDcyLWEzZTAtMGJiODQ1ZTUxMGQ4/edit?hl=en&pli=1
RUR is offline
Old 03-06-2014, 10:13 AM
FMW
FMW's Avatar
Liked: 1686
So where in this article do they compare MCACC with any other room calibration routine? Are we going down this road again?
FMW is offline
Old 03-06-2014, 10:28 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 376 Post(s)
Liked: 258
...You are talking about the difference between room calibration and no room calibration. I am talking about the difference between two different room calibration systems. Are we going down this road again?
I'm talking about the differences between room correction systems, and Harman's research shows that differences in RC products absolutely affect user preferences for SQ.
What are you talking about?
RUR is offline
Old 03-06-2014, 10:40 AM
FMW
FMW's Avatar
Liked: 1686
I'm bored with this. Sorry. If I retract everything I said, will that satisfy you?
FMW is offline
Old 03-06-2014, 10:47 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 376 Post(s)
Liked: 258
Stop advising folks that differences in Room Correction products are subtle and unimportant, when your opinion is contrary to a properly conducted blind study from a respected source.
No different than me posting in an amp thread that my Ampfinity Mega-Mk XXVIIB with mods makes a Crown amp sound like ****e. You'd have a cow.
RUR is offline
Old 03-06-2014, 10:56 AM
FMW
FMW's Avatar
Liked: 1686
So apparently it won't satsify you. Take care.
FMW is offline
Vsx 92txh Elite Home Theater A V Receiver , Emotiva Xmc 1
