Unable to join iPad to Yamaha 3030 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-08-2014, 05:28 PM - Thread Starter
bobshafer's Avatar
I just purchased a new Yamaha 3030 AV receiver. Although the remote was not back lit, I was told that it was easy to download a piece of soft wear that was wonderful to use. I am unable to download the soft wear and connect it to the AV receiver. Anyone else have this problem?
Bob Shafer
bobshafer is offline
post #2 of 3 Old 03-08-2014, 07:03 PM
Chad Varnadore's Avatar
Liked: 52
I don't have an ipad, so I can't help you there. It's also my understanding that the downloadable app is better than the supplied remote, but the remote for the 3030 is definitely backlit (button on the righthand side).
Chad Varnadore <><
ex-armchair quarterback
Our HT
Chad Varnadore is offline
post #3 of 3 Old 03-08-2014, 10:16 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Bob Shafer
The 3030 remote is back lit. Are you trying to obtain the "Yamaha Remote App" for iphone? If so, go on the app store, click the search icon, and type in "Yamaha AV Controller", then hit "open" ...it's free, and it works wonderfully. I also use my Samsung 7" tablet for the screen size. What are you trying to do?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
Yamaha Rxa3030bl Aventage Home Theater Receiver
