Outlaw 7125 bridgeable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 03-09-2014, 06:57 PM - Thread Starter
Ckindt's Avatar
Liked: 35
Hi.
I haven't found any definitive answers.
Is the 7125 bridgeable? I'd like to use two channels to power one speaker.
Onkyo TX-NR929/11.1 | Outlaw 7125 | Polk:  CSi A6 C | RTi A9 powered by qsc gx5  L&R | tsx110b Ht,Wd,SS and SB | Sub - Rythmik FV15HP | Samsung 60" UN60F8000BF | Samsung BD-F5900 | Theater Room
Ckindt is offline
post #2 of 21 Old 03-09-2014, 11:38 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Nope.
kikkenit2 is offline
post #3 of 21 Old 03-10-2014, 06:07 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
Originally Posted by Ckindt View Post
Hi.
Why? Are you aware that bridging causes the amp to see 1/2 the impedance of the speaker? What is the voltage swing and how much do you need?
FMW is offline
post #4 of 21 Old 03-10-2014, 07:52 AM - Thread Starter
Ckindt's Avatar
Liked: 35
I acquired a set of RTIA9s to replace my monitor 60s (front left and right) and I was considering existing options to provide the 9s with more headroom.
Between my onkyo 929 and the outlaw I have plenty of channels to spare in my 11.1 setup so I can sacrifice 4 channels on the outlaw for two 9s.
I read a thread on the outlaw site that passively bi-amping is a possibility by splitting the rca input to the amp across two channels and connecting the two equal amp outputs to the speaker posts. In this case more available current should equal more headroom.?
I'm not certain I'll necessarily need the headroom, but you never know.  I don't want to miss out on the 9s potential without buying another amp.
90% movies at -10db typical max volume
Ckindt is offline
post #5 of 21 Old 03-10-2014, 08:29 AM
FMW
FMW's Avatar
Liked: 1681
It will simply make your 8 ohm speaker look like a 4 ohm speaker. While it will increase voltage swing it won't have much effect on power. So headroom would not be a reason to do it.
Between my onkyo 929 and the outlaw I have plenty of channels to spare in my 11.1 setup so I can sacrifice 4 channels on the outlaw for two 9s[/quote}
If you don't need the amps, don't use them. I'm not aware of any AVR that provides for bridging. Bridging is something pro audio people use. It doesn't have much application in home audio.
Not really. It would simply split up the drivers and send full power to each rather than sending what each can dissipate. It accomplishes nothing. Proper biamplification is done by putting the crossover at line level in front of the amplifer, not in the speaker cabinets.
I'm pretty sure you won't. Based on what you are saying I would doubt that you dissipate any more than 20 or 25 watts per channel on peaks. Any AVR that I know of will handle that without difficulty. Amplifier power, strangely, is one of the least important aspects of home audio.
FMW is offline
post #6 of 21 Old 03-10-2014, 12:04 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Bridging an amplifier theoretically doubles the voltage, if the amp can still supply the current, and thus quadruples the power to the speaker (power goes as voltage squared). It does make the speaker "look like" half the impedance to the amplifier, which is why most amplifiers that do allow bridging, do not allow speakers as low in impedance as in their non-bridged mode. That is, a two-channel amp that will drive 4-ohm speakers as-is, will likely only rate the amp for 8-ohm loads when bridged. There are other issues with bridging amps, such as higher noise and stability.
I tend to agree with the rest of above, i.e. it is very unlikely you actually need to bridge the amp, even if you could.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #7 of 21 Old 03-10-2014, 03:24 PM - Thread Starter
Ckindt's Avatar
Liked: 35
Thanks for the valuable insight.
I'll just leave everything as is and will likely be pleased.
This post in the outlaw saloon is misleading me.
They talk about leaving the jumper bars on the speakers and running two amp channels with the same signal split from the receiver.  Wouldn't this allow for more available current?
Ckindt is offline
post #8 of 21 Old 03-10-2014, 03:39 PM - Thread Starter
Ckindt's Avatar
Liked: 35
If you don't need the amps, don't use them..
I need at least two channels of the 7125, but use them all.  The 929 only has 9 amps and requires 2 external amps for the 11 channel output via pre-outs.
Currently I only run the FL,FR,BL and BR off the 929 so it can focus its power on the fronts mostly.
Ckindt is offline
post #9 of 21 Old 03-10-2014, 03:56 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
If your speakers are bi-ampable, you could use Y cable unless that causes a problem with shorting inputs or something like that. I used a two channel poweramp to bi-amp my center.
fatbottom is offline
post #10 of 21 Old 03-10-2014, 04:25 PM - Thread Starter
Ckindt's Avatar
Liked: 35
hmm..:confused:
This is not recommended for real results.  My speakers are bi-ampable, but this still leaves the internal crossovers in tact and you are supplying a full range signal to each post set.
I was inquiring about running two full range signals from two separate amp channels with the same source signal to both speaker input posts and leave the jumper bar jumped.
Ckindt is offline
post #11 of 21 Old 03-10-2014, 04:30 PM
fatbottom's Avatar
Liked: 518
If you use a av amp, then pre-outs are filtered are they not (set them to small 80hz for example) I don't know if you can use one of these- contact Outlaw
http://topzoneonline.com/rca-y-cable-1-rca-plug-to-2-rca-plugs-3-inch.html
My poweramps a have in/out type connection
http://att.jdbbs.com/forum/day_070304/20070304_d2c0580ec2ca40ec3afaFCiDjkqG1lZp.jpg
Take short cable from load left, to input right. Input left is the RCA cable from the pre-amp
ummmm. No? BANG
post #12 of 21 Old 03-10-2014, 04:57 PM - Thread Starter
Ckindt's Avatar
Liked: 35
ummmm. No? BANG
i don't understand your recommendation on the wiring.
I don't think the amp would go bang since there is no short circuit. With the jumpers left the load should be the same to both amp channels, but is there any benefit?
Ckindt is offline
post #13 of 21 Old 03-10-2014, 04:59 PM
fatbottom's Avatar
Liked: 518
If you use two amp channels on your amplifier, but leave the speaker shorting links (biamp speakers) your amps WILL BLOW UP.
YOU MUST REMOVE THE SPEAKER SHORTING LINKS
CORRECT way.
http://forum.audio.com.pl/index.php?act=attach&type=post&id=1773
post #14 of 21 Old 03-10-2014, 06:11 PM - Thread Starter
Ckindt's Avatar
Liked: 35
CORRECT way.
are you sending full range signals to all posts and letting the speakers' internal crossovers and filters determine what frequencies make it to the drivers or are you conditioning the signal to the amp first?
Ckindt is offline
post #15 of 21 Old 03-10-2014, 06:13 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
You can bi-amp, but not bridge your amp. Big difference. Some car amps and some pro amps can bridge channels.
Very few home theater amps can bridge 2 channels into one. And going from 125 watts per channel to 200 isn't
going to change the performance of your speakers anyway.
post #16 of 21 Old 03-10-2014, 06:20 PM - Thread Starter
Ckindt's Avatar
Liked: 35
Yeah, i'm at that conclusion, but am just trying to sort out this bi-amping thing. Why so common if so useless?
Thanks everyone for being patient with my ignorance.
Ckindt is offline
post #17 of 21 Old 03-10-2014, 07:11 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
It is called marketing. Once one brand offered it and sales boomed, everybody else copied it so they wouldn't be left behind. Same thing with speakers. We see people all the time want speaker brand a instead of speaker brand b just because of dual binding posts with metal jumpers. A $5 part made some people rich. Polk even puts them on their cheap bookshelf speakers. Just don't let your jumpers come loose.
post #18 of 21 Old 03-11-2014, 01:09 AM
fatbottom's Avatar
Liked: 518
I use a high pass filter so my amps don't receive <80hz. And that is what saps power.
post #19 of 21 Old 03-11-2014, 06:33 AM
FMW
FMW's Avatar
Liked: 1681
The industry is good at catering to beliefs.
FMW is offline
post #20 of 21 Old 03-11-2014, 12:18 PM
Mr. Tao's Avatar
Quoted: 12 Post(s)
I have been Bi-Amping my front L&R Polk RT8 speakers for a few years now using an Onyko 805, 7.1 receiver. The 805's additional 2 channels can be used to Bi-Amp the Polks, as I use a 5.1 setup, and the resulting sound is noticeably more accurate & stable. It seems Bi-Amping can minimize or eliminate Intermodulation Distortion, (IM), between the crossovers in the speaker by providing power directly to the Bass/Midrange & Tweeters independently. It just sounds cleaner and maybe a bit sharper than not Bi-Amping. By the way Bi-Wiring is totally useless and produces no advantage in your audio system.
Mr. Tao is offline
post #21 of 21 Old 03-11-2014, 04:45 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
