New Receiver or Oppo-103 Blu Ray Player? - AVS Forum | Home Theater Discussions And Reviews
Old 03-10-2014, 12:04 PM - Thread Starter
Gratefulvol's Avatar
Sorry in advance for the long post....I have recently moved into a new home which will have a dedicated media room which is 15x12.  So far the setup will include a new Sharp LC-60EQ10U, Pionner Andrew Jones line of speakers with the FS52 for mains, SVS SB-1000 Subwoofer, Apple TV, PS3, and cable box.  I have a Harman Kardon AVR230 receiver from an old setup.  The remaining budget will allow for a new mid-range receiver while using my PS3 for a Blu Ray player or keep the HK receiver and go with an Oppo-103 which can be used for HDMI switching with the 2 HDMI input.  The old receiver has both 7.1 analog inputs and output should I ever decide to upgrade to an external amp (possible Emotiva UPA-700). The HK is only rated at 50Wx7.  I am only running 5.1 currently but plan to possibly upgrade in the future as the room is wired for front and rear speakers.
So, which would I be better off with?  A new receiver or the Oppo?  Would the room EQ in a new receiver be more beneficial or since the room layout is pretty basic would I be OK to setup the EQ on my own?  I have never experienced Audyssey, YPAO, etc.
If going with a lower price receiver such as the Denon X1000 or Marantz NR1403 I could possibly do both but not sure if those would meet my needs long term.
If getting a new receiver, below are what I am considering as Best Buy/Magnolia are currently running a sale in store which is not reflected online.
Denon X1000 -$349 (only 5.1)
Denon X3000 - $699
Marantz SR5008 - $819
Marantz NR1403 - $379
Yamaha A-830 - $659
Yamaha A-1030 - $899
Thanks in advance for any assistance or input!
Gratefulvol is offline
Old 03-10-2014, 12:35 PM
JameyF's Avatar
IMO, I would up the budget a bit and go for the Denon X4000. Call JDSmoothie from AVS for a reasonable price. It's VERY close to your later choices, and I just purchased one from him a few weeks ago. He is very easy to deal with.
Later when 4k is more mature get the Oppo of choice then.
JameyF is offline
Old 03-10-2014, 01:04 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 8447 Post(s)
Liked: 3799
Not sure how much of a difference you're going to notice between the PS3 and the Oppo, rather the upgrade to either Audyssey MultEQ XT (X3000) or XT32 (X4000) would be the bigger improvement.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
Oppo Bdp 103 3d Blu Ray Player , Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Harman Kardon Avr 230 Audio Video Surround Receiver , Emotiva Upa 700 Seven Channel Power Amplifier , Denon Avr X1000 5 1 Channel Home Theater Receiver , Denon Avr X3000 7 2 Channel Home Theater Receiver , Marantz Sr5008 , Marantz Nr1403 Slim Line Av Receiver , Yamaha Rx A830 7 2 Channel Network Aventage Home Theater Receiver , Yamaha Aventage Rxa 1030 Receiver
taboola here
