Your thoughts on x4000 compared to 4520ci... - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By mercury
  • 1 Post By mercury
Old 03-10-2014, 02:51 PM - Thread Starter
mercury's Avatar
Liked: 101
My set-up is PSB spekares and dual PSA XS30'S....
I have no interest in extra zones as i use a niles keypad system-
im interested in tuning up my speakers n subs... is the 150 wpc that much better then the 125 wpc.... anything else i should know??
thanks-
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
Old 03-10-2014, 06:27 PM
GIEGAR's Avatar
Quoted: 373 Post(s)
Liked: 721
@mercury, the difference between 125W and 150W is 0.8dB [dB = 10 * Log (Pout / Pin)]. For reference, it's generally accepted that 1dBSPL is a "just noticeable difference" in loudness.
Denon also quote Power Output Per Channel (6Ω, 1kHz, 0.7% THD) of 165W & 210W, and Maximum Power Output Per Channel (whatever the heck that is?) of 235W & 260W for the X4000 and 4520CI respectively. These figures equate to differences of 1dB and 0.4dB.
The message is: don't buy the 4520CI for the extra power over the X4000 - it makes no appreciable real world difference.
Here is a side by side comparison: http://usa.denon.com/us/Product/Pages/ProductComparision.aspx?CatId=2011incommandreceivers(denonna)&pids=avr4520ci(denonna)|avrx4000(denonna)
If you're not interested in zone capabilities, you would buy the 4520CI over the X4000 if you needed things like: 9 channels of amplification &/or 11.2 channels of simultaneous processing or 9 channel free amp assign capability. Just about everything else is fluff, IMO.
(BTW: What PSB's are you running?)
GIEGAR is online now
Old 03-10-2014, 07:00 PM
cfraser's Avatar
Quoted: 121 Post(s)
Liked: 72
The X4000 is a good deal. If I already had a 4520 I certainly wouldn't change it for the X4000. The 4520 is built to a noticeably higher standard than the X4000, if that matters to you. And the 4520 is rated for 4 ohm speakers, not that that matters to you, now at least, but does indicate more robust amps than the X4000's. I do not use the X4000's amps myself (I do have some 4 ohm speakers) so have no listening opinion of them, but it does make a decent feature-laden pre-pro.
So considering the 4520 costs ~double what the X4000 does, it's likely not the most cost/beneficial solution for you of the two.
cfraser is offline
Old 03-10-2014, 07:35 PM - Thread Starter
mercury's Avatar
Liked: 101
Thanks guys..big help!!
Im running PSB T45's fronts c15 surrounds-. along with dual PSA's xs30's
here's the thing. I'm really looking to upgrade from my Pioneer to get better dual sub EQ... as I understand it the 4520 does not EQ dual subs the way the x4000 does. that brings me to the Denon 4311CI. tough to find I know but worth it over the x4000?? I want the best MultEQ® XT32 I can get. is the 4311CI ON par with the X4000 as far as MultEQ® XT32....
thanks much-
ohioratrodder likes this.
Denon 4520*
Squeezbox*
mercury is offline
Old 03-10-2014, 07:44 PM
cfraser's Avatar
Quoted: 121 Post(s)
Liked: 72
^ I believe that the XT32 and SubEQ HT on the X4000, the 4311, and the 4520 are identical, never heard otherwise here. That is the only reason why I got the X4000: the 4311 disappeared very quickly from stock here in Canada when I wasn't paying attention (gotta buy Denon here to get the warranty) so I missed it (waffling...), and the 4520 seemed a bit expensive since all I wanted was the improved Audyssey (vs my older Denon AVR). The XT32 is definitely worth it compared to the other versions of Audyssey.
Edit: there are other features/capabilities that the X4000 has that neither the 4311 or even the 4520 have. Don't underestimate them until you see what you can do with them. Then again, the 4311 and 4520 have "legacy" capability that you might be using now, that the X4000 might not have. Be sure to check that, it is one of the things that occasionally bugs me, and is more likely to catch you if you don't update AVRs that often.
cfraser is offline
Old 03-10-2014, 07:54 PM - Thread Starter
mercury's Avatar
Liked: 101
Thanks. my understanding which may be wrong is the 4520 does not do multi sub... still trying to get an answer... for some reason on amazon crutchfield and such always mentions the x4000 with multi sub eq but never mentions the 4520 or the 4311 as having it....
ok correction. it seems that Audyssey Platinum is available on the 4520 and the x4000 but not on the 4311.... so I guess they all do dual sub....
so price wise it would be between the 4311 and x4000 if xt32 is the same on both....????
Denon 4520*
Squeezbox*
mercury is offline
Old 03-10-2014, 07:58 PM
cfraser's Avatar
Quoted: 121 Post(s)
Liked: 72
^ They all do multi subs, as long as "multi" means two: they have two sub connectors, more subs than that and you have to use Y-adapters to hook them up. Also the Audyssey menus and speaker menus etc. allow for two separate subs (or "arrays" of subs). Maybe you can look at pics of the AVR back panels on the Denon/Crutchfield sites, or here if you go to the first posts in the dedicated threads (possibly necessary for the 4311).
cfraser is offline
585-645-1006
jdsmoothie's Avatar
Quoted: 7310 Post(s)
Liked: 3365
The 4520CI has the same version of Audyssey MultEQ XT32 and also Sub EQ HT (dual subs) and in fact was the first Denon AVR to include these features. It has a much more robust power supply that is capable of powering 4-ohm speakers at reference level volume which the X4000 is not able to do. It is currently Denon's flagship AVR with better components and the only current model manufactured in Japan.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
Authorized dealer: Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
Old 03-10-2014, 08:32 PM - Thread Starter
mercury's Avatar
Liked: 101
Thanks guys. Jd so you would choose the 4520 over the 4311. Thanks. Just trying to cover all bases
Denon 4520*
Squeezbox*
mercury is offline
Old 03-11-2014, 06:02 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
If you have difficult (low impedance) speakers, the 4520CI is the better option otherwise an external amp would have to be added with the X4000. With easy to drive speakers, it depends on your requirements as each model can do a few things that the other cannot.
Old 09-05-2014, 08:46 AM
Skrill's Avatar
Quoted: 224 Post(s)
Liked: 64
Sorry to ressurect this old thread -- but, in reference to the quote above, I was wondering what in particular that the X4000 can or does do that the 4520 does not. I currently have the X4000 and am thinking about the 4520 given the great deals out there now.
Skrill is offline
Old 09-05-2014, 09:03 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
1. X4000 can do PCM 2.0 HDMI/optical/digital coax/analog to Zone 2 and PCM 2.0 optical/digital coax/analog to Zone 3 while 4520CI can only do analog to Zone 2. Both can do on board sources (Pandora, Internet radio, USB) to Zones 2/3.
2. X4000 can display HDMI video source while listening to USB, Tuner, CD, Network, Phono source. 4520CI can only display analog video sources with another audio source.
Old 09-05-2014, 09:16 AM
Skrill's Avatar
Quoted: 224 Post(s)
Liked: 64
Thanks -- exactly what I needed. Any difference in the actual speed or responsiveness of the GUI (like when paging through lots of network music)?
Skrill is offline
Denon Avr X4000 7 2 Channel Home Theater Receiver , Denon Avr 4520ci Receiver , Xs30
