Pioneer VSX32 - AVS Forum
post #1 of 2 Old 03-13-2014, 03:00 AM - Thread Starter
bangingit's Avatar
Hello ,
Looking for any ideas that would allow me to stream audio to the VSX32 from my Samsung S4
AND or
be able to listen to Internet radio on VSX32 for cheap .
Finally do I need anything to listen to internet radio using the VSX? Like a antenna? I have the VSX plugged into mt internet and cant get any Internet Radio stations . Sorry I am somewhat new at the internet are there any sites I can go to to see how to hook up and find radio stations ?
bangingit is offline
post #2 of 2 Old 03-14-2014, 02:33 AM
lovinthehd's Avatar
Quoted: 206 Post(s)
Liked: 780
According to the product blurb you need a Pioneer AS-BT100 Bluetooth adapter to stream from your android device. From the blurb doesn't seem to have built in network apps but does have ability to handle Sirius and do network radio input with a usb keyboard. Maybe you can use your Pandora app in the S4 or something like that? I didn't check the manual, did you? Did you look for the official thread for this model receiver?
lovinthehd is offline
Pioneer Elite Vsx 32
User Tag List
