Basically Need and Airplay Pre-amp. Does it Exist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-13-2014, 02:08 PM - Thread Starter
slim1998's Avatar
I am helping a friend upgrade an older system in his house. It is 2 channel audio only, no video. He has a nice 2 channel amp driving 3 sets of speakers in his upstairs bedroom and balcony. It is driven by a separate preamp and fed with a cd changer and am/fm tuner. I am looking to get rid of the cd changer, tuner and preamp and replace them with a preamp that has Airplay. My first thought was to buy a cheap AV receiver and use the zone 2, but I understand that some units have issues when outputting airplay sources to zone 2. I have settled on the Yamaha RX-V775WA, but this seems like a lot of hardware to basically stream Airplay content and control the volume. SO the question is...is there something out there that fits my needs without over-buying a bunch of stuff I do not need. Ease of use is the #1 priority.
slim1998 is offline
post #2 of 2 Old 03-13-2014, 08:44 PM
Worf's Avatar
Quoted: 569 Post(s)
Liked: 307
If you just want airplay, then an AppleTV or airport express (the AppleTV supports video, while the airport express is audio only) will suffice as the only thing you need...
Worf is offline
Yamaha Rx V775wa 7 2 Channel Network Av Receiver
