No idea where to start for a receiver (mid-high end) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-15-2014, 12:16 AM - Thread Starter
moonpuncher's Avatar
Hello all,
I am putting together my new home theater a piece at a time.
I started withi a 64" Samsung F8500 plasma <-- it's awesome
I'm about to pick up two Definitive Technology 8060ST towers and the matching center channel.
I will eventually add some smaller surrounds and a single subwoofer.  My question is this: How the heck do I know what to look for in a receiver to make sure I get enough volume with these speakers?  I don't really care about 3d video, won't need any fancy wi-fi features, and really don't know what price range receiver would be appropriate for this level system.
Any guidance on price range, models, and what kind of features I need to watch out for would be hugely useful.  I have a decent understanding of how home theater and audio work but I'm having trouble finding out the differences between a $500 and $1500 receiver.  Would rather trust you guys than the kid at Best Buy.
moonpuncher is offline
post #2 of 3 Old 03-15-2014, 12:27 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Those Def Tech speakers are fairly efficient so most any AVR will be able to easily drive them to loud volume levels. For Denon models, review posts #1 and #2 in the Owner's thread linked below to get an idea of what features are available at each price point. Note also that depending on your time frame the new 2014 models of all brands will start being released in the next several months so you can either wait to get a good clearance deal on a 2013 model or get the newer features on the 2014 models.
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23134184
jdsmoothie is offline
post #3 of 3 Old 03-15-2014, 01:13 PM
Jack D Ripper's Avatar
Liked: 272
Normally, there is not a lot of difference in power between comparably priced units.  And not usually a very dramatic difference between most receivers generally.  If you are worried about having enough power, you should look for a receiver with preamp outputs, so that you can add an external power amplifier, which can be as powerful as your budget allows.  Most likely, though, unless you listen at literally deafening sound levels, you don't need any more power than a normal receiver.
As for receivers in different price ranges, you tend to get more and more features as you move up the line.  Which features are useful will depend on what gear you want to connect to it, and what you want to accomplish.  For example, some of the expensive receivers, like this one (which is discounted because it is last year's model, and is what I would buy if I were buying something at its price point of $1500):
http://www.crutchfield.com/p_022RXA3020/Yamaha-AVENTAGE-RX-A3020.html
have great video processing.  But that may not matter to you, if all you are going to do is watch BDs.  And it may not matter if your TV has great video processing (I have no idea about your particular model).  The receiver also has many other features that could be nice to have, but most of which are probably not going to be necessary for you, though it really depends on what you want to do.
Here is another receiver I would consider (and is what I would currently buy at its price point of $700):
http://www.crutchfield.com/p_022RXA1020/Yamaha-AVENTAGE-RX-A1020.html
It is also from last year, which is why it is discounted.  It is likely that it, too, has more features than you need.  But, again, it depends on what you need it to do.
If you want advice on features, you might want to tell us everything that you plan on hooking up to it.  But judging from your statements about not needing fancy features, most likely, you will be happy with a $500 unit instead of one of the more expensive ones above.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
