Banana plugs touched, screwed up receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-16-2014, 05:37 PM - Thread Starter
Jay Brent's Avatar
Banana plugs on my right front speaker touched and apparently have done some damage to my Pioneer vsx-70 receiver. The receiver is about 10 weeks old, and has barely been used.
I just bought Energy CF-70's, popped in the plugs and it sounded great.  But then I accidentally jarred the speakers and the plugs touched.  Now any speaker I try on that channel crackles badly.  Since I screwed up, not sure if this will be covered under warranty. And even if it is, according to Best Buy, it should take about 3 weeks to get the receiver back.
I'm new to home theater, and have limited audio skill set.  I've posted this on couple of forums without much luck.  I'm hoping some experts here can advise me how to resolve this.
 - Is this fixable? Or, have I completely torched the receiver, and need to replace it with a new one?
 - Is this typically covered under warranty? Or should I just look for a service center nearby that can get it done more quickly, though I'll have to pay?
 - Is this something easy to fix - maybe something I can do myself?
Any help would be greatly appreciated.  Thanks in advance.
Jay Brent is offline
post #2 of 12 Old 03-16-2014, 07:13 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
For an avr like this why didn't BB just take it back and exchange it? I also wonder why its protection didn't kick to protect it from something like this. Take it back and tell them its faulty and you want an exchange. What you did should not have junked that AVR.
Jay Brent likes this.
phantom52 is offline
post #3 of 12 Old 03-16-2014, 08:16 PM
ChrisTheKid's Avatar
Liked: 25
I don't really have an answer to your questions. But when wiring anything, always leave some slack on one side.
Panasonic TC-P65VT60
Pioneer Elite SC-55
Klipsch RF-3, RP-3, RC-3, RS-3
Bang & Olufsen Beogram TX
Pioneer Elite BDP-62FD
XBOX-360, XBOX-ONE, PS3(60GB)
ChrisTheKid is offline
post #4 of 12 Old 03-16-2014, 11:16 PM
WMConey's Avatar
Quoted: 32 Post(s)
I did *exactly* the same to a surround channel on my VSX-1122-K. $100 to replace an output transistor at a [relatively] nearby Pioneer repair location. Of course, I spent several days believing it was the speaker, ordering a replacement driver... never thinking to swap speakers to see if the issue followed the channel or the speaker. So you're already ahead of the game!
I wasn't under warranty, otherwise it would have been free. I think it will be faster for you to avoid going through Best Buy. Any authorized Pioneer repair center should honor the warranty.
Chill... look up the nearest repair center on their website.....
WMConey is offline
post #5 of 12 Old 03-17-2014, 05:59 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It is my opinion based on decades of experience with audio gear that any amplifier that is damaged by a casual short circuit is by definition defective either by design or by random failure of parts.
Any well designed modern amplifier should have ample reserves to its circuit design and built in protection circuits to survive a simple fault such as a temporary short of speaker leads.
The Service manual for the VSX-70 lists its various forms of protection of its output circuits:
(1) "To detect high DC output from amplifier damage (defect status)."
(2) "A process to protect speakers (for protection of connected external devices)."
(3) "To detect overloading (abnormal status) with low-load driving or a short circuit of the speaker terminals (for protection of the amplifier)."
(4) "To detect overheat of inner temperature"
The above are direct quotes. What you did seems to be covered in (3).
This is not unsual. The above are the usual kinds of protections that one finds in modern power amps of all kinds and in all price ranges.
I'm not an expert but I can obtain and correctly analyze relevant manufacturer documentation at times. This question seem to have a clear answer, direct from Pioneer's engineering staff!
Just about anything that goes wrong with a receiver can be repaired. It is just a matter of costs and benefits.
I don't know why you would need to pay anything if the receiver is under the manufacturer's warranty.
Nope. I've done it many times and an effective safe repair takes experience, tools and parts that are not readily available to ordinary people. Also, its not your fault - the AVR is supposed to handle this sort of thing by at worst shutting itself down temporarily until the short is removed. To be at fault by permanently damaging this AVR you would have to do something crazy like plugging it into a speaker output into an AC wall socket.
arnyk is offline
post #6 of 12 Old 03-17-2014, 11:01 AM - Thread Starter
Jay Brent's Avatar
Past return date, so the best they could do was send it out to be serviced.  They couldn't even tell me if it would be covered.
Thanks WMConey.  That's why I didn't want to go through Best Buy - I figured if I brought it to a local service center it would be much quicker.
post #7 of 12 Old 03-17-2014, 11:05 AM - Thread Starter
Jay Brent's Avatar
Arny - thank you for that really insightful answer; especially the service manual quotes.  This gives me ammunition, just in case.
I'll bring it in tomorrow and post back in case anyone is interested.
post #8 of 12 Old 03-18-2014, 08:38 AM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
I purchased several Monoprice speaker wall plates. On the front side you can connect bare wire and screw down the binding post, or use banana plugs. I notice that the two binding posts are dangerously too close, when using banana plugs, (that is if the gold plated exterior posts are in fact "hot"). If this is the case, why do they make them this way?? I folded a piece of paper and slid it in between the posts. Of course one could slip a rubber sleve around the post as well.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #9 of 12 Old 03-18-2014, 06:36 PM - Thread Starter
Jay Brent's Avatar
Tangent issue - I'm now looking for banana plugs with insulated jackets, so I don't have to worry about this happening again in future.  I found some Monster plugs but they are ridiculously expensive ($20 per plug).
Can anyone recommend inexpensive plug with non-conductive body (to prevent shorts)?
post #10 of 12 Old 03-18-2014, 06:43 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
http://sewelldirect.com/Sewell-Deadbolt-Banana-Plugs-1-Pair.asp
http://sewelldirect.com/Sewell-Deadbolt-Banana-Plugs-12-Pair.asp
post #11 of 12 Old 03-18-2014, 08:02 PM
mastermaybe's Avatar
Quoted: 362 Post(s)
Liked: 306
Well, I don't have a banana plug recommendation for you, but instead, would suggest to simply terminate bare wire.
In 20 years I have yet to hear a convincing argument as to why it's beneficial to add another point of potential failure to an avr/amplifer loudspeaker connection in a typical home scenario. If I had a dollar for everytime I heard of banana plugs popping out and shorting though I'm certain I could end up with a nice steak dinner.
To a guy swapping out gear weekly I guess they might make some sense, to the rest of us going months or YEARS with the connections, where's the upside? Looks prettier?
If that's the case whatever helps you sleep at night I guess.
Sorry and good luck with the repair.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #12 of 12 Old 03-19-2014, 12:06 AM - Thread Starter
Jay Brent's Avatar
