Sound Drop Out - AVS Forum | Home Theater Discussions And Reviews
Old 03-28-2014, 05:28 AM - Thread Starter
sjoGM's Avatar
Hope someone can help, I am stumped. I use an Oppo BDP93 and two Directv dvrs with my Marantz AV8801. On a random basis the sound will drop out for a half second or so, like a glitch. The system behaves likes this with both dvrs and the Oppo playing blu-ray and regular dvds.
There is no video drop out.
I run hdmi to the Marantz from all three pieces.
When I notice the sound drop out with the dvrs, I hit the back button to rewind and play again. The sound plays perfectly without the just experienced drop out.
Suggestions?
Enjoy the Forum. Thanks.
sjoGM is offline
Old 03-28-2014, 07:08 AM
McStyvie's Avatar
Liked: 78
I think the first and easiest thing to do is check the cables for loose connections, and/or replace them.
McStyvie is offline
Old 03-28-2014, 12:28 PM
MarkGierke's Avatar
I think if you searched around that you would find you are not alone with this problem. I have seen and read of it affecting equipment from Onkyo, Denon, Yamaha, and in your case Marantz. Nobody seems to have a clue what causes this. Changing HDMI cables I can almost guarantee won't fix it based on what I've seen. Good luck and if you find a resolution please be sure to post it!
MarkGierke is offline
