Denon AVR-E300 and MacBook Pro - AVS Forum | Home Theater Discussions And Reviews
Old 03-28-2014, 09:48 AM - Thread Starter
calahandle's Avatar
Just got my new receiver set up (despite a total lack of knowing what I was doing) and so far everything worked fine (Airplay, projector, Wii, dvd player) but when I plugged the MacBook Pro into the Denon via hdmi, I couldn't get any sound. The picture worked fine, but not sure how to get the sound to work. Is that a setting or is that a completely different cable that needs to be used for audio conversion?
Thanks in advance.
calahandle is offline
Old 03-28-2014, 10:02 AM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
Did you change the setting on the Macbook to output sound over the HDMI?
I think it's "system preferences > sound > Output > select the HDMI" but I don't have the setup to test it right now.
Good Luck!
walterappleby is offline
Old 03-28-2014, 10:14 AM - Thread Starter
calahandle's Avatar
That worked!
Thank you, Walterappleby. :)
Old 03-28-2014, 10:49 AM
Quoted: 25 Post(s)
Liked: 77
Welcome. Glad it was easy for you.
