AVR with audiophile level audio? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 04-04-2014, 06:44 PM
TheGSRGuy's Avatar
Quoted: 17 Post(s)
The Class-D amps in newer AVRs are looking good. OP, you might want to look into something like that.
Marantz AVR & monoblocks + MartinLogan Motion 3.1 setup
TheGSRGuy is offline
Old 04-04-2014, 06:47 PM
Bond 007's Avatar
Quoted: 1783 Post(s)
Liked: 1607
Originally Posted by seiyafan View Post
That's a good price indeed. What about Yamaha or Marantz? Are they all similar under $700?
Note that Denon is refurbished.
No, Mr. Bond. I expect you to die!
Bond 007 is online now
Old 04-04-2014, 06:48 PM
dougri's Avatar
Liked: 40
If you are considering refurb, the cambridge audio 650r is also in your price range.
dougri is offline
Old 04-04-2014, 10:15 PM - Thread Starter
seiyafan's Avatar
Quoted: 28 Post(s)
Liked: 25
After much research, I have to decide between Yamaha A820, A1010, Marantz SR5006, or NR1604
What do you guys think?
seiyafan is offline
Old 04-05-2014, 02:00 AM
Bond 007's Avatar
Liked: 1607
All good choices. I would get the A1010.
Good choice of speakers as well.
Old 04-05-2014, 04:59 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
All of those are good choices but I would go with this Denon AVR-2312CI:
http://www.crutchfield.com/p_033AV2312C/Denon-AVR-2312CI.html?cc=07&tp=179
Audyssey MultEQ XT that equalizes the sub
Decent OSD
7.2
Three Year Warranty
Crutchfield's awesome lifetime support and customer service.
If you want a Yamaha, then this 1020, which is a year newer:
http://www.crutchfield.com/p_022RXA1020/Yamaha-AVENTAGE-RX-A1020.html?tp=179
bladerunner6 is offline
Old 04-05-2014, 05:11 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1234
Originally Posted by etc6849 View Post
It's true that most AVRs can't keep up with the impedance swings of woofers
Several myths in one short statement:
(1) There are many cases where the worst swings in impedance curves are not due to woofers.
Consider this speaker whose worst impedance swings are above 10 KHz:
(2) That AVRs can't handle them is a myth.
and do have under powered power supplies driving multiple amps,
What reliable evidence is there that AVR power supplies are underpowered for the purpose of driving speakers with music or drama?
but if you have a well treated room with a sub (best to have dual matching subs), you can set the cross-over high in the AVR to take load off the AVR's amp and get great sound.
Yet another myth. It is true that a subwoofer takes a signficiant load off of both the LCR speakers and by implication the AVR. I know of no instances where people are setting crossover frequencies excessively high because the AVR can't handle the speaker load. I'm surely not doing that!
I wouldn't expect a $500-700 AVR to provide "audiophile" quality, but if you invest your money in highly efficient speakers and dual subs you probably can get a very nice sounding system.
Audiophile quality is a myth. Even just mid-priced AVRs use many of the same ICs, resistors, capacitors, power transistors, and DACs as are found in separates.
arnyk is offline
Old 04-05-2014, 06:21 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1674
Looks good. I would choose the A820 from your list. It will do everything you want to do and more. And, it will avoid having a system with audyssey which is not adjustable. The Yamaha will allow you to tailor the room correction to your preferences. You want that in a 2 channel system. Now you can begin saving for a subwoofer.
FMW is offline
Old 04-05-2014, 01:55 PM
Jon S's Avatar
Quoted: 728 Post(s)
Liked: 240
Originally Posted by FMW View Post
Unfortunately none of this has anything at all to do with sound quality. Zero.
I beg to disagree... I have a Yamaha RX2400 receiver, rated at 120 watts per channel. I also have an Acurus integrated amp rated at 100 watts per channel. The two amplifiers have definitely different sound characteristics. I have a Magnepan 1.6 speaker rated at 5-ohms. When driving the speaker with the same source, the Acurus sounds more dynamic with tighter bass.
My HT system used to be powered by an Onkyo TX-NR906 and i replaced it with a Pioneer SC67. The Onkyo sounded a bit more dynamic than the Pioneer but the Pioneer does not sound as harsh or grainy as the Onkyo.
If it's not a BIG screen, it's not a theater...
Jon S is offline
Old 04-05-2014, 02:02 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Don't waste your time mate.
Hell I borrowed a Roksan Kandy K1, bloody awful it was...really harsh sounding.
fatbottom is offline
Old 04-05-2014, 05:48 PM
FMW
FMW's Avatar
Liked: 1674
You can disagree but I won't listen to your disagreement until you have done a level matched bias controlled comparison.
FMW is offline
