Speakers and Amp Pairing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-05-2014, 09:23 PM - Thread Starter
drainyoo's Avatar
Hi, I'm a newbie to the audio world, and I'm setting up a simple system. I currently have a Braun Atelier A1 amp with 2 x 55 Watts at 8 Ohms, and I'm interested in purchasing the Pioneer SP-BS22-LR speakers, which are 80 watt at 6 ohms. Will I have any issues with this pairing? My main concern is the amp since it's from the 80s, and a little rare. I don't want to damage it in any way.
Will I be ok, or should I find speakers that are 8 ohms and similar wattage?
Thanks for the help.
drainyoo is offline
post #2 of 13 Old 04-06-2014, 05:59 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I foresee no problems. Speaker impedance specifications are not rock solid and depending on manufacturer I can imagine the same speaker being rated either way.
arnyk is offline
post #3 of 13 Old 04-06-2014, 06:45 AM - Thread Starter
drainyoo's Avatar
Thanks. What about the watts? I've read that the amp should have twice the wattage of the speakers. Will I be fine in terms of power even though the amp had less watts per channel?
drainyoo is offline
post #4 of 13 Old 04-06-2014, 06:47 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
You'll be fine. either under powered or over powered is ok. I've used 25W amps, and I have now 180W per channel (most powerful) I'd recommend at least 50W per channel, as I found the 25W to sound a bit bloaty on the low end.
I have to be careful with my speakers, as both are 4ohm, one has 88dB sensivity, sides are 87dB so need bit of power and capable PSU.
fatbottom is offline
post #5 of 13 Old 04-06-2014, 07:24 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
The 80W rating of the speakers is the MAXIMUM power they can safely handle, not the power required. A 30 or 40 watt amplifier is enough for most speakers.
Just because a tire is rated for up to 130 MPH, that doesn't mean you have to put them on a car that can go 130 MPH.
You amp has plenty of power for those speakers; no problem. Your typical listening level will require only a few watts.
The impedance rating of a speaker is only an approximation/average, since the speaker actually has different impedances at different frequencies.
To really understand the impedance of a speaker, you need a GRAPH of its impedance vs. frequency.
Stereophile did an article on those speakers, and you will find the impedance graph for them at the end of the article. I suggest that you look at it and print it for reference.
Their impedance actually varies from 4.5 ohms at 250 hz to over 20 ohms at several other frequencies.
A typical speaker could have an impedance of 5 ohms at 80 Hz, 18 ohms at 600 Hz, and 7 ohms at 3kHz etc. etc.
Every speaker system is different.
Its pretty arbitrary whether the manufacturer calls it an 8 ohm or 6 ohm speaker or whatever.
commsysman is offline
post #6 of 13 Old 04-06-2014, 07:52 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
How many versions of the same answer do you need?
If I'm so incompetent that I didn't consider something obvious like the potential issue with power, then simply forget my advice.
What is unclear about "I foresee no problems"?
arnyk is offline
post #7 of 13 Old 04-06-2014, 07:56 AM
fatbottom's Avatar
Liked: 519
Just buy a Krell 900E
POWER!
post #8 of 13 Old 04-06-2014, 08:05 AM
comtom's Avatar
POWER!
:rolleyes:
comtom is offline
post #9 of 13 Old 04-06-2014, 08:19 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
That which is obvious to a superior person like yourself may require some degree of explanation to clarify the issues for a novice.
Relax and take a deep breath...lol.
post #10 of 13 Old 04-06-2014, 08:23 AM - Thread Starter
drainyoo's Avatar
Wow, you need to relax. I was asking because you only addressed the impedance.
Anyway, thanks everyone for the info. It's been really helpful. I have a better understanding of how these specs work.
drainyoo is offline
post #11 of 13 Old 04-06-2014, 08:39 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Your answer in post 5 was great.
Too bad about the pent up anger thing...
arnyk is offline
post #12 of 13 Old 04-10-2014, 04:41 PM
Flagos22's Avatar
I find your opposing comments confusing:
"There is more to an amplifier than power, you need to read up I've hooked up a 25W Rotel into large floorstander speakers. Sounds great."
http://www.avsforum.com/t/1327107/the-official-yamaha-rx-v671-thread-7-1-channel-network-avr/1920#post_23235394
Flagos22 is offline
post #13 of 13 Old 04-11-2014, 02:31 AM
fatbottom's Avatar
Liked: 519
I had two different types of floorstanders at the time, one was a easier load and more sensitive than the other. Also I was playing with crossovers so in full range, it was a bit bloaty but setting to small helped.
Wheras using a more powerful amp, in full range, didn't sound so bloaty.
