New Reciever? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 04-07-2014, 03:52 PM - Thread Starter
tegguy's Avatar
Alright everyone I am looking for a new receiver to replace my old Denon that doesn't even have HDMI. I need recommendations please trying to be budget conscious (unless I wait). I am running 2 Monitor 60's and a CS2 for the front and 4 Monitor 40's for the surrounds. I saw newegg had a good deal on a Yamaha today http://www.newegg.com/Product/Product.aspx?Item=0MJ-0022-00014
What are your thoughts on it I'd like to stay in the $400-$900 range but the cheaper the better. I defiantly want something with network capability.
tegguy is offline
post #2 of 15 Old 04-07-2014, 04:34 PM
smithhayward's Avatar
Hey Tegguy, I recently picked up the Pioneer VSX-1123-K.  It's network-capable (wired out of the box - requires an adapter to make it wi-fi) and there's a free app, iControlAV, available for phones/tablets. So far I really like it, but it's not fully setup.  Check the manual online - you'll see several setup options between 7.1, 5.1 + Zone2 audio, 5.1 + ZoneHD, etc.
This is an out-going model and BestBuy and Amazon had it for just under $400.  I just did a search and it seems like it's gone from Amazon and has been replaced by the VSX-1123 (no "-K") for $600 which I assume is just the current model.
I'm sure the current one is as good if not better, but you might want to try to track down the -K model to save some cash.
Vecuronium likes this.
smithhayward is offline
post #3 of 15 Old 04-07-2014, 04:39 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
That is an excellent buy on that Yamaha.
phantom52 is offline
post #4 of 15 Old 04-07-2014, 05:10 PM - Thread Starter
tegguy's Avatar
Would you buy that over the Yamaha?
Would you buy it?
tegguy is offline
post #5 of 15 Old 04-07-2014, 05:20 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3060 Post(s)
Liked: 2980
I'd get another Denon myself. You should give us here at AV Science a call.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #6 of 15 Old 04-07-2014, 05:23 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Yes I would at that price. Ask this in the Yamaha thread for that AVR.
post #7 of 15 Old 04-07-2014, 07:49 PM
No, if the choice was that Yamaha for $450 or the 1123 for $600, I'd choose the Yamaha.  If you want your AVR to be connected via WIFI then also go with the Yamaha.  If you can find the 1123 for $400 it's a heck of a deal too.
post #8 of 15 Old 04-08-2014, 09:35 AM - Thread Starter
tegguy's Avatar
I'm currently looking at the RX-V775 for $450 or the Onkyo 818 for $649. Thoughts/opinions? Go with neither and suggest a different model number?
tegguy is offline
post #9 of 15 Old 04-08-2014, 09:57 AM
Cro-man's Avatar
Go for the Yamaha more dependable. Onkyo is not reliable. I should know I had an 807 that quit after two years.
Sent from my Galaxy Nexus using Tapatalk
Cro-man is offline
post #10 of 15 Old 04-08-2014, 11:51 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Yamaha easily out of these two.
post #11 of 15 Old 04-08-2014, 12:04 PM - Thread Starter
tegguy's Avatar
I'm contemplating saving up and getting the denon x4000. Is it worth the extra $800 (when its not on sale)
tegguy is offline
post #12 of 15 Old 04-08-2014, 12:13 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
That X4000 is MSRP at that price. Give jdsmoothie a call here at the AVS Store for a price.
http://www.avsforum.com/u/7847949/jdsmoothie
post #13 of 15 Old 04-08-2014, 05:32 PM - Thread Starter
tegguy's Avatar
I think for the time being I'm jus going to hold off. I'm liking the Denon X4000 but the price is up there. I think I need to do more research before I buy a receiver it's been too long since I have shopped for them the features have changed. What kind of wattage should I be looking for per channel?
tegguy is offline
post #14 of 15 Old 04-08-2014, 08:12 PM
PinkFloydQ's Avatar
I have a denon avr1513 i can sell you
PinkFloydQ is offline
post #15 of 15 Old 04-08-2014, 08:30 PM
The kind of wattage you need will depend on your application.  I'm a quasi-home theater buff, meaning that I like good sound, but never BLAST anything and don't care to shake things for the sake of shaking things.  Budget usually drives my entire purchase because if I need to eat ramen noodles everyday for 3 years to afford my HT equipment then I'm doing something wrong.  For me this resulted in the Pioneer I mention above (VSX-1123-K), followed by a pair of Polk RTi4 bookshelf speakers for R/L with a CSi5 for my center speaker ($100/speaker).  For surround I went with a Monoprice 3-way in-wall for my Front Hight speakers and Monoprice 2-way 6-1/2 inch for surround and rear surround (around $50 per each pair).  I got a SINGLE Polk PSW10 for my subwoofer ($125).  My console cost me $268 from a furniture store that I was already buying bedroom furniture from and the TV is a 47" 1080p 60Hz Westinghouse display we already had (I'm getting divorced).  I'll be saving up for both a HTPC and a 4K/UHD display for the coming year and see where I go from here...
That all said, 135W/Ch is plenty for me.  Your mileage may vary...
