Denon avr-1713 with air track sound bar - no sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-12-2014, 05:51 PM - Thread Starter
amb1s1's Avatar
I have a ps3 connect to the game input on the avr and the avr out to the airtrack hdm1 subwoofer. The subwoofer out to the the hdm1 on the tv. I can see the video of the ps3 but no audio.
amb1s1 is offline
post #2 of 8 Old 04-12-2014, 06:04 PM
jdsmoothie's Avatar
Quoted: 15369 Post(s)
Liked: 7517
Review the instructions with the sound bar. A quick google shows that In order to use the sound bar, apparently either the TV must support HDMI(ARC) or you must connect an optical cable from the optical audio output on the TV to the sound bar.
jdsmoothie is offline
post #3 of 8 Old 04-12-2014, 06:08 PM - Thread Starter
amb1s1's Avatar
I just wanted to confirmed witch part I'm having issues and I connect the ps3 to the receiver and the receiver out to tv and I still don't hear the audio. In this case the tv has to support arc too since the avr hdmi out is arc?
amb1s1 is offline
post #4 of 8 Old 04-12-2014, 06:14 PM
jdsmoothie's Avatar
Liked: 7517
If all you have is the sound bar, there is no reason to use the 1713. Simply connect the PS3 to the sound bar and connect the sound bar to the TV.
post #5 of 8 Old 04-12-2014, 06:43 PM - Thread Starter
amb1s1's Avatar
I actually connect the way you say and I still no sound on my LG smart tv.
amb1s1 is offline
post #6 of 8 Old 04-12-2014, 07:02 PM - Thread Starter
amb1s1's Avatar
I have the ps3 out to hdm1 in on the subwoofer and subwoofer out to the tv hdm1. It was working before and now I can just see the video no audio
amb1s1 is offline
post #7 of 8 Old 04-13-2014, 04:55 AM
jdsmoothie's Avatar
Liked: 7517
The TV must have HDMI(ARC) enabled which means setting the HDMI-CEC to ON (eg. Anynet+, BraviaSync, VieraLink, etc). as well as setting the TV audio to "External speakers" or "Home Theater".
post #8 of 8 Old 04-13-2014, 09:05 AM
JChin's Avatar
Quoted: 377 Post(s)
Liked: 210
Hi amb1s1, first try to re-established working video and audio by connecting the PS3 directly to TV via HDMI. If still no audio but video is fine, try resetting the PS3 by pressing and holding the power button for 5 seconds until you hear 2-3 beeps. If still having problem try a new HDMI cable.
JChin is online now
