Onkyo looks to have announced the new TX-NR838 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 06-09-2014, 07:40 PM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
Originally Posted by David Susilo View Post
SMPTE ST202
Sorry, not up on my SMPTE jargon.  I did a quick google search and only had a couple hits, one a presentation by Toole.  Did really have the answer I was looking for.  Happen to have a freq plot, image or link for me?  Thanks.
primetimeguy is online now
Old 06-09-2014, 07:52 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
SMPTE ST202 target curve graph
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
Old 06-09-2014, 08:22 PM
Quoted: 556 Post(s)
Liked: 359
Thank you, so looks pretty close to Audyssey curve and others in the high frequency rolloff. Interesting no rise in the bass.
Old 06-09-2014, 10:18 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Those filters look exactly like what Yamaha uses. 31.5hz to 16khz. Don't like that deep bass curve either. What happens below 30hz? Suppression?
kikkenit2 is offline
Old 06-09-2014, 10:21 PM
Quoted: 612 Post(s)
Liked: 584
my home theatre
Old 06-09-2014, 10:23 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Man. I thought you knew everything. lol Thanks for the graph. Competition for audyssey is a good thing.
David Susilo likes this.
Old 06-10-2014, 05:18 AM
Quoted: 612 Post(s)
Liked: 584
I'm still learning everyday either from trainings, white paper, or from fellow professionals, engineers, everybody. smile.gif
my home theatre
Old 06-10-2014, 10:46 AM
zeus33's Avatar
Quoted: 1333 Post(s)
Liked: 989
Not like I needed to see that graph to know they screwed up by dropping XT32, but that is worse than I expected. It ignores your main speakers (really?) and starts dropping bass at 50hz? WOW! Idiots. Nail meet coffin.
zeus33 is offline
Old 06-10-2014, 10:49 AM
zeus33's Avatar
Liked: 989
But it's not competition. It's like comparing a crank window Toyota Tercel to a fully loaded BMW 7 series. AccuEQ pales in comparison to XT32.
zeus33 is offline
Old 06-10-2014, 10:57 AM
Quoted: 612 Post(s)
Liked: 584
I guess the entire team of SMPTE and Dolby are idiots according to you right? :rolleyes.gif:
pdxrealtor likes this.
my home theatre
Old 06-10-2014, 10:59 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Same here and I have learned a lot from you.
Old 06-10-2014, 11:02 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
I tend to agree. We need worthy competition. XT32 extended my bass pretty flat down to 18hz.
I paid a lot for those lower frequencies. I don't want them suppressed or boosted a lot.
Old 06-10-2014, 12:37 PM
edgeh2o's Avatar
Quoted: 46 Post(s)
Liked: 35
How does calibrating with REW or TrueRTA compare to XT32? Is it worth the time?
Can you run Audyssey to get time alignment/non-EQ stuff computed, and then perform your own EQ? I've come to realize that I don't really like a flat response (I generally like a small dip around 1khz-6khz for music depending on the room and speakers, among other adjustments), and would prefer to use a different target curve to EQ to where I like.
Office - Onkyo 506, AV123 X-LS Encore Monitors
Living Room - Panasonic 60ST60, Onkyo 707, Ascend Acoustics Sierra-1 LCR
Car - Focal Flax 3-ways; Arc Audio KS 2500.1, 300.4, 300.2; Audison BitOne; Digital Designs 3515
edgeh2o is offline
Old 06-10-2014, 01:22 PM
kokishin's Avatar
Quoted: 799 Post(s)
Liked: 487
It appears that the roll off at the low end is ~2.7dB/oct based on being down -2dB from 50Hz to 31.5Hz. Presuming the slope continues linearly, 25Hz should be -2.7dB, 20Hz should be -3.24dB, 12.5Hz should be -5.4dB.
My signature:
Link: avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me.
kokishin is online now
Old 06-10-2014, 02:14 PM
zeus33's Avatar
Liked: 989
Did someone from either group tell Onkyo it was smart to ignore the two main speakers? I think not. If they did, then yes, IMO, they are idiots. I was calling Onkyo idiots for cutting corners and using a generic room EQ program, that is inferior to the solution that they were already using. Yes, I know it's all about saving money.....
The desired curve that SMPTE is after is what they "think" it should sound like. That's fine for their standard, but people here spend thousands of dollars to get down to 20hz and below. Why would they want the response to start dropping off at 50hz? Sure, you can try to EQ it flat all the way down, but for some that would require purchasing more equipment (MiniDSP, DSP built into the sub amp, etc.) and spending more money to achieve the same results. This can be resolved, ignoring the two mains can't.
zeus33 is offline
Old 06-10-2014, 02:25 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 420
EZ solution...
Buy the stepup AVR model that includes XT32..
Just my $0.05... 👍😉
M Code is offline
Old 06-10-2014, 02:29 PM
zeus33's Avatar
Liked: 989
Originally Posted by M Code View Post
EZ solution...
Just my $0.05... 👍😉
Not if you stay in the Onkyo lineup. They did away with Audyssey completely according to this:
Onkyo AccuEQ will be used for their entire lineup. They developed this feature in collaboration with Dolby Labs.
zeus33 is offline
Old 06-10-2014, 02:48 PM
Quoted: 612 Post(s)
Liked: 584
The SMPTE curve is the reference standard. If you want to deviate from that, go ahead, but don't assume your preference is correct.
Accuracy can be mutually exclusive to preference. In your case, it is. In my case my preference is to achieve accuracy as intended by the industry...which is SMPTE.
my home theatre
Old 06-10-2014, 02:54 PM
Quoted: 556 Post(s)
Liked: 359
But isn't that the reference for theaters?  We watch in much smaller rooms, even if they are home theaters.
Old 06-10-2014, 02:55 PM
zeus33's Avatar
Liked: 989
Agreed. I know that some of us are bass heads and that is not an "accurate" curve. I didn't mean to imply that it was "correct". It's just personal opinion.
Maybe you can answer this. Why did Audyssey not use this curve if it is the industry standard? I'm not trying to argue, just genuinely curious. What standard or curve is the Audyssey calibration based on?
Thanks for your insight.
zeus33 is offline
Old 06-10-2014, 03:35 PM
Quoted: 612 Post(s)
Liked: 584
I've experienced Audyssey XT32 with SMPTE curve on certain models (they naame it Movie Curve or something like that). Depending on the manufacturer, Audyssey also use different curves such as Paul Barton's RoomFeel curve in its NAD processors.
Pioneer MCACC, for example, uses the curve preferred by Air Studios sound engineers with a user option to use the curve of the main L/R and how they interact in the room then applying that curve to the rest of the speakers.
As in why they don't comply to SMPTE, because the SMPTE curve don't sound "exciting" enough for many.
Nearly all my clients, for example, prefer a reasonably flat response with slight bumps in 25 Hz and/or 35 Hz plus a roll-off of around 1 dB/octave above 4 kHz.
I haven't played with the AccuEQ myself, however from the demo/training I attend, after the auto cal is done, the user can go to the EQ and play with the EQ without the need of a pro-kit. Also AccuEQ allow the user to choose the front-speaker curve just like Pioneer MCACC.
I know I'm not truly answering your question, but that's all I know regarding Audyssey in general and all I'm allowed to explain about AccuEQ. Suffice to say, there is a big reason (not monetary) why Onkyo shift to AccuEQ
my home theatre
Old 06-10-2014, 03:40 PM
QuentinH's Avatar
How is AccuEQ for dual sub configurations? My favorite part of MultiXT32 is the (usually) included Sub EQ HT. Can AccuEQ compete?
QuentinH is offline
Old 06-10-2014, 03:42 PM
Quoted: 612 Post(s)
Liked: 584
You are absolutely correct, hence there are variations on the graph shown depending on the size of the theatre. For home, although there will be roll-offs, they won't be as "severe" as the "small theatre"
my home theatre
Old 06-10-2014, 03:47 PM
Quoted: 556 Post(s)
Liked: 359
sub Eq only sets level and distance for two subs. It still eqs them as one. For most on these forums it really is not needed as it can be done manually.
Old 06-10-2014, 03:56 PM
zeus33's Avatar
Liked: 989
Excellent info. Thank you David.
zeus33 is offline
Old 06-10-2014, 03:57 PM
Quoted: 612 Post(s)
Liked: 584
Until I've played with the actual unit, I don't know the answer to this.
my home theatre
Old 06-10-2014, 06:41 PM
Schwa's Avatar
Quoted: 992 Post(s)
Liked: 1057
Ooh, how mysterious. rolleyes.gif I guess the implication here is that Onkyo developed their own solution, from scratch, purely because they thought Audyssey was no longer up to snuff? And it took them (at least) six generations of receivers/processors to figure this out? I'm not buying that Audyssey's licensing fees and Onkyo's focus on the bottom line weren't at least part of the reason behind Onkyo dumping Audyssey.
I hope AccuEQ is the real deal -- that's better for everyone because it gives the consumer more options and it'll force Audyssey to refrain from resting on their laurels. But Audyssey has a relatively long history of highly-regarded performance so it's not a surprise that enthusiasts might be skeptical of AccuEQ. It's gonna take more than platitudes for AccuEQ to measure up, much less improve upon, what we know Audyssey delivers.
Schwa is offline
Old 06-15-2014, 07:00 AM
RUSaved's Avatar
Quoted: 18 Post(s)
Liked: 7
Wanted reciever
I was looking at getting a Onkyo TX-NR838. Well which one should i get now.
RUSaved is offline
Old 06-20-2014, 05:20 PM
IgorZep's Avatar
Quoted: 386 Post(s)
Liked: 185
How can this accuracy be achieved
a) With only one measurement point?
b) Worse... when you bypass EQ of front channels?
So, it doesn't work already by definition (according to their own marketing claims)!
I don't buy the religion. Setting up a HT is a technical task, so I need to know properties of component I am selecting for it. If unknown - they do not exist. You are trying to sell a pig in a poke. If there is a big reason (technical, not monetary) name one!
Schwa likes this.
IgorZep is offline
Old 06-20-2014, 06:06 PM
Quoted: 612 Post(s)
Liked: 584
I have NDA, all insiders have NDA they have to adhere to. No need to be rude.
my home theatre
