Best flagship A/V receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-18-2014, 06:25 AM - Thread Starter
Kain's Avatar
Quoted: 1200 Post(s)
Liked: 329
Between the Onkyo TX-NR5010, Yamaha RX-A3030, and the Pioneer Elite SC-79, which would be the best match for my Klipsch RF-7, RC-7, and RS-7? I have a 5.1 setup with a single SubMersive. My Klipsch speakers are the original models from back in 2002. I need an A/V receiver that can drive them to reference levels with ease and, of course, have excellent sound quality. By the way, I am also open to other suggestions for A/V receivers so please suggest any if you like. I would like to stay away from separates right now.
Kain is offline
post #2 of 19 Old 04-18-2014, 06:52 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
I would avoid Onkyo. Too many reliability issues. Whether to choose a Pioneer or Yamaha boils down to which room correction software you like better. MCACC or YPAO. Personally for a 5.1 system, you can save money by getting a lower end unit as the higher end units main advantage is being able to process 11 channels. You won't notice much difference in amp power between say 150 watts and 120 watts.
KidHorn is offline
post #3 of 19 Old 04-18-2014, 06:53 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Chuck in Arcam, NAD, Anthem, Harmon Kardon too?
fatbottom is offline
post #4 of 19 Old 04-18-2014, 07:37 AM
oztech's Avatar
Liked: 101
Hard to beat the amps in the SC-79 and you mentioned you want to drive these at reference levels and with that being said there are deals right now because the new models are about to be released in the following months .
oztech is offline
post #5 of 19 Old 04-18-2014, 07:39 AM
seiyafan's Avatar
Quoted: 28 Post(s)
Liked: 25
Arcam, NAD, Cambridge Audio, Rotel (in no particular order)
Not sure if McIntosh makes a receiver or not.
seiyafan is offline
post #6 of 19 Old 04-18-2014, 07:53 AM
almadacr's Avatar
If you want XT32 why not also Denon and Marantz ?
almadacr is offline
post #7 of 19 Old 04-18-2014, 11:16 AM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
With a sensitivity rating of 101dB any receiver can drive your speakers to reference with ease. It will take all of 4W to exceed reference levels at 1M. At 4M you will need 16W. Even an entry level receiver can make your ears bleed at 4M. No need for a flagship level receiver just to drive your speakers. There may be reasons you will want a flagship receiver, but the power and ability to drive your speakers to reference levels is not one of them. What it boils down to is what features do you really want. Buy based on that and product reliability.
duc135 is online now
post #8 of 19 Old 04-18-2014, 11:34 AM
oztech's Avatar
Liked: 101
I could not find a complete review to see how the impedance varies across the band or phase shift but on sensitivity alone an iPod would probably drive them .
oztech is offline
post #9 of 19 Old 04-18-2014, 03:01 PM
Quoted: 73 Post(s)
Liked: 112
Anthem gets my vote.
rnatalli is offline
post #10 of 19 Old 04-18-2014, 03:39 PM
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
With those speakers and 5.1, I'd get the Anthem MRX-310. Not flagship, but no need for higher in the anthem lineup with your speakers/setup. Of the others you listed, and if you prefer more mainstream, I like the yamaha-3030, and I'd replace the Onkyo with the denon 4520ci as well.
dougri is offline
post #11 of 19 Old 04-18-2014, 03:45 PM - Thread Starter
Kain's Avatar
Liked: 329
I'll have to wait a few more months before I'll be able to purchase this but I'm thinking Parasound Halo A 51 + Onkyo PR-SC5509. Good combo? How is the PR-SC5509?
Kain is offline
post #12 of 19 Old 04-18-2014, 03:52 PM
oztech's Avatar
Liked: 101
The Halo stuff is top notch but I would look elsewhere for a pre-pro especially for reliability.
oztech is offline
post #13 of 19 Old 04-18-2014, 03:54 PM
oztech's Avatar
Liked: 101
Personally the Flagships from Denon ,Marantz and Pioneer would give you what you want .
oztech is offline
post #14 of 19 Old 04-18-2014, 04:02 PM - Thread Starter
Kain's Avatar
Liked: 329
How about the Parasound Halo A 51 + Yamaha AVENTAGE CX-A5000?
Kain is offline
post #15 of 19 Old 04-20-2014, 11:05 AM - Thread Starter
Kain's Avatar
Liked: 329
Any comments as to how the Pioneer Elite SC-79 and the Yamaha AVENTAGE RX-A3030 compare? First priority is sound quality (high SPL, excellent dynamics, and a generally smooth/warm sound as I have "brighter" speakers). Am I correct in assuming that the Yamaha is better built?
Kain is offline
post #16 of 19 Old 04-20-2014, 11:23 AM
dwaleke's Avatar
Quoted: 1114 Post(s)
Liked: 515
If you are looking for "smooth/warm" I'd lean toward the Yamaha over the Pioneer. I have had a CX-A5000, RX-A3020, and a SC-75. While all are good units the SC-75 is the farthest away from that description when compared to the Yamaha you are looking at.
dwaleke is offline
post #17 of 19 Old 04-20-2014, 12:08 PM
arftech's Avatar
Quoted: 157 Post(s)
Liked: 123
Arcam AVR-750 especially if sound quality is a concern.
Enjoy the music!
Al
Oppo UDP-203, Anthem AVM50V 3D Pre-Pro, Krell KAV-500 3 Channel Amp, Adcom GFA-535 2 Channel Amp, Cary Audio 306/200 CD Player, Emotiva Stealth DC-1 DAC, Oppo HA-2 DAC/Amp, Hifiman HE-500 Headphones, Audeze EL-8 Headphones, Westone UM 50 Pro in ear monitors, Apple PowerBeats 3, MacBook Pro, Apple iPad Pro, Sony XBR65X930C, Sonus faber Luito Towers, Sonus faber Luito Monitors, Sonus faber Smart Center Channel, REL T2 sub, Sony SWF-BR100W Wireless Subwoofer for 930C
arftech is offline
post #18 of 19 Old 04-20-2014, 01:22 PM
oztech's Avatar
Liked: 101
Try and demo any piece of equipment with as close to if not the model of speakers you have then base your own opinion not mine or others .
oztech is offline
post #19 of 19 Old 04-22-2014, 01:16 AM
ShenToN's Avatar
Try to look for ADA Rapture a/v receiver smile.gif
ShenToN is offline
