Hook up turntable to Denon AVR2112CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-20-2014, 10:14 AM - Thread Starter
steve mark's Avatar
I can't get my turntable to play thru my receiver. The manual says that the phono button can't be
used. Any suggestions?
Thank you
Steve M.
steve mark is offline
post #2 of 3 Old 04-20-2014, 10:47 AM
jdsmoothie's Avatar
Quoted: 12139 Post(s)
Liked: 5529
The 2112CI doesn't have a PHONO input so the button on the remote will not work. You would either need to use a TT with a built-in pre-amp or connect first to a 3rd party phono pre-amp and then connect to any analog input on the 2112CI. You would then select whatever source name you plug the TT in to on the remote.
jdsmoothie is offline
post #3 of 3 Old 04-20-2014, 01:31 PM - Thread Starter
steve mark's Avatar
Thank you very much for the information. I will
be in touch.
Steve
