Significant trouble setting up Denon E-300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-22-2014, 09:43 PM - Thread Starter
arao89's Avatar
Hi all,
Been lurking for a few weeks now, as I am trying my hand at setting up a 5.1 system. So far, I have a Denon E-300 receiver and 2 JBL 180 floorstanding speakers. No center, surround speakers, or subwoofer as of yet. Another thing is that my HD tv does not support ARC and I haven't picked up an optical cable just yet, but will tomorrow.
So far, I have only connected my computer to the receiver as an input. My tv is of course the output. Video setup is good and well, and the computer screen passes through when the receiver is turned off. No sound, however, no matter what I try. When I plug in the Audyssey microphone to the amp, nothing happens. The setup booklet says a setup screen should show up, but it doesn't. The option to manually enter Audyssey setup is also blacked out and cannot be accessed, even when the Audyssey microphone is plugged in.
I have ensured that my two existing speakers have been connected appropriately. No clues what to do at this point and google has been of no help so far. Any insights would be appreciated!
arao89 is offline
post #2 of 6 Old 04-22-2014, 10:34 PM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
Try to connect a more standard input source besides computer like a cable tv box or dvd player. Could be a computer setting. The setup program should auto detect mic input, but receiver should play audio without running audyssey. And search for the dedicated denon E thread.
kikkenit2 is offline
post #3 of 6 Old 04-22-2014, 10:40 PM - Thread Starter
arao89's Avatar
Thanks for the advice. I forgot to mention that I tried connecting the cable box (via the composite yellow/red/white cables). Neither video nor audio worked in this case. The video did not work because the receiver popped up and said that it could not convert a composite connection to hdmi (since it's connected to tv via hdmi), so there's that. But still, no explanation for audio.
Unfortunately, don't have any game systems that I could test out.
arao89 is offline
post #4 of 6 Old 04-22-2014, 10:57 PM
kikkenit2's Avatar
Quoted: 823 Post(s)
Liked: 305
Call Denon. That looks fatal.
post #5 of 6 Old 04-22-2014, 11:12 PM - Thread Starter
arao89's Avatar
based on what i've seen so far on google, it looks like the norm for the e-300. http://www.crutchfield.com/S-DyoXKUOetGK/compare_033AVRE300_033AVRE400/Denon-AVR-E300-vs-Denon-AVR-E400.html
arao89 is offline
post #6 of 6 Old 04-22-2014, 11:13 PM - Thread Starter
arao89's Avatar
based on what ive seen on google, it looks like that's simply the case for the e300. example: crutchfield. com/S-DyoXKUOetGK/compare_033AVRE300_033AVRE400/Denon-AVR-E300-vs-Denon-AVR-E400.html (cant post links)
arao89 is offline
