Headphone input controlled via Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-24-2014, 05:22 PM - Thread Starter
Iain Sheppard's Avatar
Hi All,
hopefully someone can help me here, I have a low end amp (Denon AVR-591) and looking if there is amp that will allow me to turn the Headphone's on and off via a the remote?
All my AV gear is under the house and I have a set of Audio Technica ATH-ANC9 that I want to cable to under the house.
If someone has any ideas this would be awesome!
Iain
Iain Sheppard is offline
post #2 of 8 Old 04-24-2014, 10:02 PM
Ross Ridge's Avatar
Liked: 81
Nope. All receivers will turn on and off the headphone output automatically depending on whether something is plugged in.
Ross Ridge is offline
post #3 of 8 Old 04-24-2014, 10:47 PM - Thread Starter
damn I was really hoping there would be an override on some higher end amps or a trick to get it to work frown.gif
post #4 of 8 Old 04-25-2014, 04:41 AM
jdsmoothie's Avatar
Quoted: 12110 Post(s)
Liked: 5511
Not with those headphones, no, but if you were to change to a set of wireless headphones you could plug the transmitter into the SB/FH pre-outs and select the Multi CH Stereo mode when you wanted to listen through them. Otherwise, with a higher level model, you would connect them to the Zone 2 pre-outs and select Zone 2.
Iain Sheppard likes this.
jdsmoothie is online now
post #5 of 8 Old 04-25-2014, 05:56 AM - Thread Starter
Thanks for the reply. What amp would be good for dual zones?
post #6 of 8 Old 04-25-2014, 01:05 PM
jdsmoothie's Avatar
Liked: 5511
Wireless headphones come with their own amp that is built in to the transmitter.
http://en-us.sennheiser.com/audiophile-headphones-wireless-digital-rs-220
post #7 of 8 Old 04-25-2014, 02:43 PM - Thread Starter
Thanks for the reply. I was looking at replacing the amp with a 2 zone amp, what would you suggest there?
post #8 of 8 Old 04-26-2014, 05:02 AM
jdsmoothie's Avatar
Liked: 5511
Ah . ... misunderstood ... you meant a Zone 2 AVR. The Denon X2000 is a 7CH or 5.1/Zone 2 unit and would be a very nice upgrade to your 591 as it uses the more advanced Audyssey MultEQ XT and has Zone 2 pre-outs.
