Amp recommendations for turntable and laptop use - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-30-2014, 05:22 PM - Thread Starter
Antabus's Avatar
I'm buying a turntable, speakers, and amp. I'm really interested in the Topping TP20 or Dayton DTA120, but they don't have phono inputs. They do have RCA inputs. Would I be able to get a phono preamp and still use it with a turntable? Or can you recommend me either an integrated amp, or phono preamp + power amp that would work with a turntable? I'm planning on getting Micca MB42X speakers. I want to use the system for both my laptop and turntable.
Thanks in advance
-Antabus
Antabus is offline
post #2 of 4 Old 05-01-2014, 11:00 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
What's your budget? Does your turntable use a moving magnet cartridge? Or a moving coil cartridge?
lovinthehd is offline
post #3 of 4 Old 05-02-2014, 06:38 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Try this one. MM/MC cartridge.
http://www.audioadvisor.com/NAD-PP375-Optional-MC_MM-Phono-Module-for-C375BEE/productinfo/NAPP375/#.U2ORP_ldV8E
There are others on this site. Excellent people to deal with.
phantom52 is offline
post #4 of 4 Old 05-02-2014, 05:03 PM - Thread Starter
Antabus's Avatar
The turntable is MM. The Pro-Ject Debut Carbon is the one I'll most likely get. I was also looking at the Rega RP1.
This is the phono preamp I'm thinking of buying because of the 3 aux inputs, on/off button, and volume knob. Is there anything I need to look for to make sure it's compatible with either of those integrated amps I'm thinking of buying?
My budget for the amps is $500 total. And this is for a desktop setup. So, listening distance will be 1-2 feet.
Antabus is offline
