Denon AVR 3805 Ext. in set-up - AVS Forum | Home Theater Discussions And Reviews
Old 05-04-2014, 04:41 AM - Thread Starter
tryst's Avatar
Hello,
I have a question regarding the analog connections for Denon AVR 3805 while using the analog outs of OPPO BDP 103 FOR dts -hd soundtracks. Currently i am using the "ext in" to get the audio but the left side of the display panel on the denon always remains blank. Is it normal or is there a way to display the input signal on the Denon screen. On the contrary, there is no problem when i use optical cable for connecting the receiver and the player through the digital set-up. Kindly help.
tryst is offline
Old 05-04-2014, 08:16 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
The Denon has no way of knowing what channels are active when using the external inputs. You need to get the channel information from the source device instead.
BIslander is offline
